how do i set up middle buster to dig deeper
   / how do i set up middle buster to dig deeper #1
botakix
i just purchased a kk middle buster and am having trouble getting it to dig the full depth of the furrower. i have adjusted my top link several different ways, but to no avail. i read a post on here, quite some time back, that mentioned something about using a shorter top link and was wondering if someone could give me some advice on this.
   / how do i set up middle buster to dig deeper #2
Top link,and have somebody stand on it....:thumbsup:
   / how do i set up middle buster to dig deeper #3
The lower 3pt arms typically have multiple holes where they connect to the upper arm. Move the connecting parts to the hole closest to the tractor. Then shorten the top link so the point of the buster is pointing downward a bit. Keep shortening it and it should dig more aggressively.
   / how do i set up middle buster to dig deeper #4
I have this same problem. Lenghtening and shortening of the top link don't seem to have much of an effect. Initially, I thought shortening would help, but as the thing dug deeper, there is more of the main beam/shaft that is submerged, and at a slight upward angle (due to the short top-link) and that begins to have more of a raising effect against the downard effect of the point. My next solution is to try to get a larger point so there will be more downward force. Last time I used it (to bury electric cable) we had two people (so about 400#) standing on it, and were able to get a large cable buried about 15 or so inches down.
   / how do i set up middle buster to dig deeper #5
Need to see a picture of your 3pt hitch to know what adjustments you have. They're not all the same.
   / how do i set up middle buster to dig deeper #6
Here's the KK MB on my Kubota B7510HST and the plowing results
This work was done in April near the end of our rainy season so the soil was pretty soft. I could bury the MB to the crosspiece that connects to the 3pt hitch lower arms.
   / how do i set up middle buster to dig deeper #7
How deep do you want it to go?
If 12", then drive the tractor up onto 12" blocks (front and back) and lower the 3 pt to see what position the point of the middlebuster is pointing. If not down in digging position, then you will have to shorten the top arm. Other depths can be checked the same way. Maybe it won't even reach as deep as you want it to go. :eek:
Having a hyd. top arm is the best, so you can start the middle buster into the ground and change the top arm as it goes deeper, to maintain a digging point.
You need to find out where that point is pointing in order to determine what you need to adjust. IMO. :) Good luck.
thanks all you guys for taking the time to respond. i will try some of your suggestions and see how it goes. i am mainly trying to go deep enough to put in a drain pipe for the downspouts off my barn. was hoping to go at least as deep as the furrower blade that came with the middlebuster, which is about 12'' inches.
   / how do i set up middle buster to dig deeper #9
Weight is your friend on top of the buster or make a bracket to hold some weight. Ken Sweet
   / how do i set up middle buster to dig deeper #10
And make more than one pass to bust open the dirt and rock. You will have to clean out the dirt anyway to lay the drain pipe in. Each pass can have a shorter top arm.
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2014 Forest River Rockwood Premier Pop Up Trailer (A59231)
2014 Forest River...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
