Install your own toothbar?
   / Install your own toothbar? #12
If it takes a big hole for your tooth bar you can use a hole saw and keep cutting fluid or even water on it to keep it cool and that works well.
A tooth bar is one of those add ons that you thank yourself over and over for installing it. I just finished adding a section of Bio-diffusers onto my septic system and that thing really made a difference.
I got a woods tooth bar and this thing is polished bright as a nickel and I haven't hurt it a bit.
   / Install your own toothbar? #13
Anyone know an online vendor that sells the Markham toothbars and or 'teeth' themselves?
:D
   / Install your own toothbar? #14
I'm with Dex3361.
If the hole is larger than 1/2" or so and or your drill motor is on the small side, use a hole saw and cutting fluid or paste of some sort. Going this way may be cheaper than a step drill. Center punch the location of the hole and it won't hurt to use a small pilot drill to insure accuracy of the location. As another poster mentioned, if you do use regular twist drills to get up to a final size, be ready for when the drill grabs as it comes through. With a larger drill motor, your wrists can take a beating.
Enjoy your toothbar!
   / Install your own toothbar? #15
Bobcat sells toothbars. Good quality if they have your size. Expect to pay about $300.
   / Install your own toothbar? #16
Does anyone sell what I call "real teeth" for a bucket? When I think of bucket teeth, I think of the teeth found on backhoe and excavator buckets.
IIRC, Deere sells individual teeth for their ss buckets. Around $100 each I think.
One thing to consider when buying a tooth bar is that it has to fit your bucket pretty closely, not only length, but also lip design. My ss tooth bucket bar hooks under the lip bar.
Ken
   / Install your own toothbar? #17
When I ordered my Markham grapple rake last spring, I also got a toothbar for the bucket on my Kioti DK45SC. I had no problem drilling the mounting bolt holes using bits from a hardware store drill set. The teeth are pretty hefty (ie, not just tines) and sort of hook over the lip of the bucket. I think the toothbar helps stiffen and strengthen the front edge of the bucket quite a bit.
BOB
I tried finding tooth bars on Woods' site. Do you have a link?
About what did you pay?
The Markham bar is $370.## delivered to my door. I'm gonna pull the trigger on that one today, unless the Woods one is a better deal.
   / Install your own toothbar? #19
Lube lube lube.
I use tons of WD40 while drilling the holes. The lube will make a huge difference and save your bits.
Wedge
Lube lube lube.
Wedge
Yeah, I've been thinking; I think I'll remove the QA bucket, stand it up on end, & ease my drill press into place. Drill with one hand & spray lube with the other.
Or just get my dad to stand there & spray :laughing:
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
