Why the whine?
   / Why the whine? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I'd say 6-8 weeks ago, there was a thread about HSTs and the topic of the whine was mentioned, as is often the case. Someone gave a nice, brief explanation of the internal design that causes HSTs to whine. I cannot find this post, and was wondering if anyone else has it or can recall such an explanation.
Thank you
   / Why the whine? #2
Thank you
The transmission pump/torque converter operates at a very high rpm and the oil really moves at a high gallon per minute/foot per second speed through small piping and control valves. The cooling fan adds to the noise as well.
   / Why the whine? #4
Sorry.. wrong whine. But just incase you get other whining... :laughing:
   / Why the whine? #5
Which Kubota HST models have a torque converters?
   / Why the whine? #6
Perhaps some good cheese to go with that whine will help :laughing:
My L3130 has some whine, more pronounced after it has been worked a bit when climbing hill.
   / Why the whine? #7
It's not unlike the noise you hear when running water. Just much higher pressure and viscosity. Very normal.
   / Why the whine? #9
Loenz,
Your 20 yrs in the hyd repair field experience is showing again......:thumbdown:
   / Why the whine? #10
All of them, torque converters are what make automatic gearboxes and HSTs possible :)
Kubota uses Piston Pump/Motor Combo Units.....The noise you hear is the oil running thru the piston rotating groups......the whine increases with pressure/velocity/torque......and/or hyd oil viscosity
Though it's a torque converter of sorts, it works on a different principle than your automatic transmission...Hydrostatic transmissions
The direction of flow and displacement is changed internally in the pump using a swashplate design (controlled by your for/rev pedals moving a lever on HST).....NOT from "small piping and control valves"....
All this is normal in Piston Pump Design.......:thumbsup:
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
John Deere 702 Hay Rake (A50515)
John Deere 702 Hay...
1268 (A50490)
1268 (A50490)
New Calf Hut (A50515)
