Why the whine?
   / Why the whine? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I'd say 6-8 weeks ago, there was a thread about HSTs and the topic of the whine was mentioned, as is often the case. Someone gave a nice, brief explanation of the internal design that causes HSTs to whine. I cannot find this post, and was wondering if anyone else has it or can recall such an explanation.
Thank you
   / Why the whine? #2
Thank you
The transmission pump/torque converter operates at a very high rpm and the oil really moves at a high gallon per minute/foot per second speed through small piping and control valves. The cooling fan adds to the noise as well.
   / Why the whine? #4
Sorry.. wrong whine. But just incase you get other whining... :laughing:
   / Why the whine? #5
Which Kubota HST models have a torque converters?
   / Why the whine? #6
Perhaps some good cheese to go with that whine will help :laughing:
My L3130 has some whine, more pronounced after it has been worked a bit when climbing hill.
   / Why the whine? #7
It's not unlike the noise you hear when running water. Just much higher pressure and viscosity. Very normal.
   / Why the whine? #9
Loenz,
Your 20 yrs in the hyd repair field experience is showing again......:thumbdown:
   / Why the whine? #10
All of them, torque converters are what make automatic gearboxes and HSTs possible :)
Kubota uses Piston Pump/Motor Combo Units.....The noise you hear is the oil running thru the piston rotating groups......the whine increases with pressure/velocity/torque......and/or hyd oil viscosity
Though it's a torque converter of sorts, it works on a different principle than your automatic transmission...Hydrostatic transmissions
The direction of flow and displacement is changed internally in the pump using a swashplate design (controlled by your for/rev pedals moving a lever on HST).....NOT from "small piping and control valves"....
All this is normal in Piston Pump Design.......:thumbsup:
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2012 Chevrolet Equinox LT SUV (A50324)
2012 Chevrolet...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
