Weight Distributing Hitch On Dump or Equipment Trailer?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #21
Do you have to modify the trailer to accept the wd? Looks like brackets or something would be mounted on the trailers.
I have two equipment trailers, one 6" channel iron tongue, and one one 12" I-beam tongue. I can make one hitch work on both, correct?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #22
You do have to mount the brackets to the trailers a-frame for the WD hitch. The brackets I use are "pinch" type that do not require welding or drilling to mount. The draw back is the trailers frame rail that you mount them to cannot be more than 2-1/2" wide. If your trailers' frames are not wider than 2-1/2" then you can get one set of them and move them back and forth between trailers with ease although I would probably just buy two sets so each trailer is already setup. That is all you need on the trailer.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #23
Crap, there goes my tool box...:(
   / Weight Distributing Hitch On Dump or Equipment Trailer? #25
How much longer does is take to hook up? Looks a little more... complicated than I am used to. A couple minutes would be worth it I guess. I'm country, we just started using balls, lights, brakes, and safety chains a few years ago:eek:. Used to just be pins.:shocked:
   / Weight Distributing Hitch On Dump or Equipment Trailer? #26
If you leave the brackets in place, under 5 minutes for both sides. I run them on our 6'X16' as the hitch load sometimes is in the 750 lb range which is over the 5000/500 limit for non WD of the hitch. With WD the hitch is rated 12000/1200.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #27
The first time you set up the hitch will take a good 20 minutes or so until you have the right height setup and know which chain link to hook on. After that, each time you hook up will take a whole 30 seconds longer than just dropping the trailer on a standard ball.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #28
It takes about as long as hooking up the safety chains.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #29
I use one on my 16' utility trailer.
What would you do if the trailer had front mounted tool box with the pump/controls in it? Would you still be able to mount the WD hitch?
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
ALUMINUM STEP LADDER (A52708)
ALUMINUM STEP...
WARREN LIGHT TOWER (A58214)
WARREN LIGHT TOWER...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
