FEL -- now we have 16'+ lift height
   / FEL -- now we have 16'+ lift height #1
ecoslik
Texas on (hobby) horse ranch
Kubota L5740 HST with LA854 loader and QA, top and tilt, 1 front and 3 rear remotes, foamed rear tires
Tomorrow, we should finish adding 26' and 30' shed roofs to the 60' length of our shop building. We are using 26' and 30' I-beams.
The challenge we had was to set and align the I-beams on top of the columns at approximately 14'-17' (max) above grade with our Kubota FEL that has 11' max lift height. These beams are too heavy to lift and carrry up a ladder, and stacking pallets on the forks for extra height and then lifting would not allow enough maneuverability of the beam during placement to perfectly align and then weld the I-beams to the columns.
We fabricated an attachment (calling it my "crane") for the pallet forks that gives us close to 18' lift height and a work platform. First we put a pallet on the forks for a work platform, and then we slotted the attachment onto the tips of the pallet forks. Since we suspended the I-beams with a single chain, we could easily fine tune alignment as we guided it onto the tops of the columns.
This was too cool! I had to share with the TBN group. Pictures are attached.
It was funny when one of the men helping me asked if I wanted him to cut the attachment apart and put the materials back on my scrap pile. Heck no ... no chance!! I'm going to find something else to build. :thumbsup:
   / FEL -- now we have 16'+ lift height #2
Very cool. Some will likely complain about safety issues. Glad it worked for you, seems like an excellent solution to the challenge.
Thanks.
You are correct about safety issues. But, I had those issues fully in mind, did some initial tests to determine certain tolerances and load balance, and then said a prayer. <joking> But, really, we did initial tests of the attachment strength, counter weight, and load balance since I had my wake up call on day one of the build when I was moving a load of columns ...
Rear wheels in the air ... http://www.tractorbynet.com/forums/kubota-owning-operating/184385-front-end-loader-rear-wheels.html
   / FEL -- now we have 16'+ lift height #4
Amazing what a "compact" tractor can do. My wife calls it "The Mule".
   / FEL -- now we have 16'+ lift height #5
By the looks other soon to be projects will be a lot easier..nice setup.
   / FEL -- now we have 16'+ lift height #6
Very nice setup.:thumbsup:
   / FEL -- now we have 16'+ lift height #8
OMG, how many OSHA violations in those pictures can you count?
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Metal Box with 32 Ratchet Straps (A57454)
Metal Box with 32...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
