Logistics of firewood hauling and splitting?
   / Logistics of firewood hauling and splitting? #71
The curve in the feather helps to get under then back up clear of snow and mud.
Sean
   / Logistics of firewood hauling and splitting? #72
my choker chains have a G or C cast shaped end that only lets one side of the chain go thru ie; | or - not +
   / Logistics of firewood hauling and splitting? #73
These are the kind we sell if that gives you an idea of how to make it.
The rope one has a few links of chain at the metal rod end to grip with a hook.
The C-Hooks that JPM mentions really are great and i got extras to use on other chain setups.
Ken
   / Logistics of firewood hauling and splitting? #74
My woodlot is 3/4 mile uphill from house on a road I don't want to scuff up from skidding. I have been changing methods also for decades.
Newest version I like. I have an old beater skidding winch (I'm getting to be in that condition myself). Cut trees in 10' lengths (stove takes 20"). Load logs with grapple onto modified bobcat trailer, stack or windrow brush with grapple. Bring trailer to shed area, unload with grapple, stack on each other for bucking. Buck and roll chunks to splitter, which has a lift. Split and toss into pile. Invite offspring to stack new chunks and load last year's pile into shed.
The trailer is the improvement here, along with the grapple. I used to haul the splitter into the woods and bring stove lengths down, but there's too much handling. Vertical: If your woodlot permits, your new trailer might be the thing that makes a working system for you. You can pull a lot with an NAA, just make sure the tongue is loaded heavy.
Jim
   / Logistics of firewood hauling and splitting? #75
Just got done pile'n up the 2012 heat and I'm sittin' here giving my arthritic knees a break. Our wood supply is from 10 acres adjacent to our home. I scout the woods for a suitable mix of poplar (about 60%) softwood (10%) and hardwood, the remainder.
Then suitable trees are selected based on death, disease, or other reasons. The trees are cut down and bucked in the woods. If chips are needed for mulch or compost they are chipped with the chipper attachment of my Ingersoll. If not they are piled in the woods for wildlife.
The rounds are then taken back to the house with the 4 wheeler and garden cart and then split with the Ingersoll splitter. Then the wood is stacked outside for at least a year, preferably two, and then brought into the barn/garage via wheelbarrow.
We only burn about three cord. We have a small home and this supplies about 98% of our heating needs. If it's real cold in the morning we'll kick the furnace on and then light the wood stove. Sometimes if it's real cold at night, below 10 degrees, the furnace might kick on once before I get up at about 5:00 to light the stove. Works for us.
   / Logistics of firewood hauling and splitting? #76
I built and use these, they work well for me, I just need to build several more!
   / Logistics of firewood hauling and splitting? #77
I am using a grade 120, 1/2 inch chain choker on my skidding winch.........
(The one on the far right in the picture) the other ones are various sizes and strengths.
That particular unit is heavy stuff, but man will it haul a MONSTER log. (in theory it is as strong as the winch at 18,000# work rate, 36,000# test strength, 71,000# break strength. And the square chain shape has never let go of a log. Makes multiple log skids via a single pull, a cinch (literally :))
   / Logistics of firewood hauling and splitting? #78
I'm like Pushing_Tin.
I drop the tree and cut to fireplace lengths on the site. Load the rounds and transport back to the house where I then split and stack.
Usually I look for blowdowns, or deaders that I thin out in the back woods; although this year I took down a bunch along the drive to keep them off the powerlines. Along the drive, I can load both the trailer and the FEL bucket at the same time. Back in the woods, I can use either one; but both at once negatively impact maneuvering around the trees to get to the trail. And since the woods back there are hilly, keeping track of rollover angles on the tractor, the bucket, and the trailer at once is really more trouble than it's worth.
   / Logistics of firewood hauling and splitting? #79
I really like your idea. How long will these last? I need a good source for pallets.
Jim
I am looking forward to trying my new trailer, I haven't decided if I will load it on stove length or log length. It's just a standard 5x10 angle iron utility trailer, but I built it extra heavy duty and designed it with more tongue weight than average. I'm also building it with a tail gate instead of a ramp for more versatility. Fully loaded it will haul 3500lbs and put about 800lbs of tongue weight on the hitch (which are the limits of my B3200, hence the design). The NAA will definitely pull more, so I might pull it with that and load it with the B3200.
PALLET OF JACKS AND JACK STANDS (A58216)
PALLET OF JACKS...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
STIHL GAS POWERED HAND HELD BLOWER (A58374)
STIHL GAS POWERED...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
CAT D5G LGP DOZER (A58216)
CAT D5G LGP DOZER...
