4320 cab and 8' garage door
   / 4320 cab and 8' garage door #11
From the floor to the bottom of the trim piece it measures 95.5".... And yes there is a slight incline.
Thanks for the measurement :D
If you do in fact only have 1 inch clearance keep in mind that the height of your tractor isn't going to be constant. There could be variables like snow on the ground, mud/chains on the tires, FEL lifting the rear up, inflation pressure, etc. that could cause the cab to scrape. Just something to consider.
   / 4320 cab and 8' garage door #12
Yes, for sure. Mine actually kinda bounces on the lugs of the R1's when I'm on hard concrete or asphalt.
-Jer.
   / 4320 cab and 8' garage door #13
It's odd that Deere made the rops 1.2 inches over 8 feet, but made the cab 1.5 inches under. I wonder if, since open station came 1st, they realized they were close and got it on the cab.
I assumed (could be wrong) that height difference was because R1 tires are taller than R3 tires.
   / 4320 cab and 8' garage door #14
I would be very leary using a garage opening with less than six inches of clearance, just to many things to go wrong. My 4520 cab has lived outside so far and has never been sick yet.
   / 4320 cab and 8' garage door #15
I have a 4320 cab with industrial tires, my garage is 7ft 11 and I can get in and out fine, I figure I probably have less than 3/8 inch clearance going in and out.
   / 4320 cab and 8' garage door #16
You're a brave soul.
-Jer.
I know what you're saying and leaving it outside probably isn't that big a deal. On the other hand, having a warm heated garage sure is nice. It gets real cold and we get a lot of snow up here in the great white north :D
   / 4320 cab and 8' garage door #18
Down here it is critical to keep tires and plastics out of sunshine as much as possible.
   / 4320 cab and 8' garage door #19
It's like that up here too..... for about 5 days per year!!!
We do actually get a lot of sunshine, just not as hot as you. The UV effects are the same though.
-Jer.
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
