radman1
Elite Member
- Joined
- Jul 8, 2006
- Messages
- 3,016
- Location
- midwest
- Tractor
- JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
It still does not sound normal to me. I would be cautious with just leaving it the way it currently sounds unless you get some assurance from you dealer or JD that they will fix it later. (You won't get that assurance.) Once it is out of warranty, it may become your problem to fix. Try another dealer or keep after the current dealer. The squeal is from something slipping. If you are not using high rpm to start the mower and you hear that squeal at lower rpms, then I suspect something is not normal. Again, this is assuming the squeal is from the tractor and not the mower. My 4520 will kill the motor before any squeal comes from the tractor when using heavy start up of a 10' rotary mower.
