7018 Vs. 7018AC, Need Layman's translation please:
   / 7018 Vs. 7018AC, Need Layman's translation please: #31
They are mild steel, do not fool yourself into thinking they are anything else.
by the second picture you did not bevel them near enough you have no
penetration into the parent metal at all.
Regrind a heavy bevel reweld with 6011
   / 7018 Vs. 7018AC, Need Layman's translation please: #32
It sure looks like cast steel to me. I would double bevel each piece. Us a piece of angle iron clamped to both pieces for alignment, preheat to 300 degrees. You can use 312 stainless steel or a rod called Super Missile Weld, but it is basically 312 stainless steel. You won't like the cost of either one of these! I have welded countless items made of cast steel with plain old 7018. Post heat is the trick here, wrap with insulation.
   / 7018 Vs. 7018AC, Need Layman's translation please: #33
Butt joint preparation.
   / 7018 Vs. 7018AC, Need Layman's translation please: #34
If they are indeed mild steel, you can do everything I said in an my earlier post except you won't need so much preheat, or postheat. ;)
I need a little further explanation of proper way to bevel.
I double beveled both halves down to a heavy 1/16th of original material touching. My bevel was over 45 degrees as well.
It didn't break in the same place either. It was close but different.
I will definitely use heat this time and go with some 312.
Any comments or suggestions about adding some reinforcements anywhere and how best to accomplish that.
   / 7018 Vs. 7018AC, Need Layman's translation please: #36
Really you think they used cast steel on a King Kutter brand "Bush Hog"
for the 3 point frame. You might want to look a little closer on what broke
and where it broke. See my modified picture.
   / 7018 Vs. 7018AC, Need Layman's translation please: #37
Ron I was just going by the picture. But now I too believe they are mild steel, but you got to admit that's some nasty looking steel / break. :confused2:
Shade Tree Welder or anyone else,
I gather from your comment, I produced a 'cold' weld, which is highly possible.
With 1/8th inch 312 rod, what would you say amperage-wise I should be using?
   / 7018 Vs. 7018AC, Need Layman's translation please: #39
Lack of penetration is the problem very clear in this picture. I see little
evidence of beveling. The yellow lines show the limit of penetration, does
not matter how much preheat, fancy super duper rod or post heat you use.
You have lack of fusion, it will fail.
   / 7018 Vs. 7018AC, Need Layman's translation please: #40
Do not use stainless rod 6011 will be perfect for this
repair 90-100 amps for 1/8".
Little Wonder High Performance Walk-Behind Leaf Vacuum (A55851)
Little Wonder High...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A55853)
2025 Nationcraft...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
CFG Industrial QH12R (A56469)
CFG Industrial...
30pc. 16ft.x 3ft. Grey Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
