1975 GMC 6500 dump truck with 366ci gas big block
   / 1975 GMC 6500 dump truck with 366ci gas big block #1
Dargo
Super Member
S. IN
Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Anybody on here ever have one of these? I don't really need a dump truck right now, but this is a one owner a family friend owns and has never sat outside overnight and I can't find any rust anywhere on the truck. He had the bed removed, media blasted and painted with some hard enamel paint about every 5 years. It has average tires, new brake booster and wheel cylinders, original interior that doesn't even have a rip in the seat and has 29,XXX miles on it.
I really don't know anything about the old 366 truck engines (he says it's a big block), but it started right away after sitting for weeks, didn't smoke and idled just fine. I wouldn't even consider this thing except it's darn near in perfect condition and I think I can get it for a reasonable price.
My questions are; is that a decent truck? It's bed looks good and is a 6 yard bed and the engine, transmission and brakes are good. My next question is what really would be a "reasonable" price for something that old?? I can't really go out of a book, because it looks better than some 2009 trucks I've seen. Any thoughts or comments on that old truck? My use would really be moving dirt on my property and saving time and wear on my tractor moving dirt 1 yard at a time.
   / 1975 GMC 6500 dump truck with 366ci gas big block #2
The 366 is a small bore tall deck Big Block. Pretty tough motors. They love fuel though.
   / 1975 GMC 6500 dump truck with 366ci gas big block #3
I have been running a 1978 Chevy C60 with a 6 yard bed, 4 speed, and a 350 2 barrel. Its a pig but gets the job done. If it did not have the high low rear end it would not move on its own from a dead stop. Its a good solid old truck that does everything we have asked of it but sure is slow. About 45 mph wide open.
He gave $1800 for it.
The same guy has a 1976 Ford F700 with a 8 yard Marion Bed, 5 speed, and a 391 truck engine with a 4 barrel. Its much more truck but the brakes are touchy and it does not look nearly as good. It will run about 55 mph.
He has $2200 in it.
He also had a 1971? GMC C40 with a 6 yard Marion Bed and a strait 6. It was about as good as the 350 powered truck and looked good but he sold it for the Ford. 45 mph was all it would do and 6 tons or less if you planned on stopping it in the same state.:D
He got $1650 for it.
I am not familiar with the 366 motor. I would go to google and look around to see what you can find out. The main issue with some of these truck motors is they are expensive if you need a rebuild or even just parts.
I would offer $2250 and see what happens.
I think I may possibly get it for less than that; possibly. I'm aware that it will suck on gas, but I expect that and it won't be used on the road much at all. It's almost a shame, because it is in such remarkable condition.
I'm waiting for insurance quotes, liability only, and to see if anyone has any real knowledge of these trucks before I go back. I've seen ones in far, far worse condition with 3X the miles go for $3500. There again, there is a sucker born every day.
It is a big block, part of the 396, 427 family. The 366 was only used in the medium duty trucks. I can't say anything on prices since they vary all over the place. Around here, you see a lot of grain trucks that they can't give away. The only negatives I would have:
1) If you ever want to put it on the road, insurance and plates can be expensive.
2) Various seals going bad from age; wheel cylinders, master cylinder, steering.
3) Tires, if you have 9.00x20 or 10.00x20, you probably have multi piece rims that many places will not touch.
Thanks, I looked at another last week that had a 427 in it. However, it smoked like crazy, had over 200k miles on it and no brakes with bald tires. I don't want to restore one. Besides, he got $2500 for it. I was not even remotely a buyer at that price.
   / 1975 GMC 6500 dump truck with 366ci gas big block #6
I have ran several trucks with that engine and all did very well. Two had 12' snow plows. I would take the 366 over a 350 in that class truck any day. The 350 lacks the lugging torque of the 366.
Dan
   / 1975 GMC 6500 dump truck with 366ci gas big block #7
I am sure you know this Dargo since you are a been there done that guy but these trucks can get real expensive real quick. Brakes are the biggy. I have seen guys dump $2000 alone on that one item. Tires, springs, ect can also get pricey. Most everything else is dead simple and any shade tree mechanic can patch them together to keep them running.
Chris
   / 1975 GMC 6500 dump truck with 366ci gas big block #8
I'm assuming it's hydraulic brakes since you said booster and cylinders. IMO air brakes are easier to work, cheaper to repair, and stop better. Not sure how GM does it but my international has a master that feeds a second master with a booster mounted under the drivers door. From what I read the two things to look out for is the diaphram in the booster leaking and the seals in the cylinders leaking. Probably why they were replaced.
I would be ready to rebuild that carb as it may not like Ethanol gas. Some other things to look at would be the leaf springs, they can get rusty and swell. It's not that you can't change them yourself but they are heavy. Also look at the grease fittings, do they look like they were used? Also take a look at the steering linkage, sometimes they are costly. For around the house some slop isn't a problem but driving on the road with a load you'll want to fix it.
My international's hydraulic pump leaked where the shafts come out of it. It's a pretty easy and cheap fix but you need to go to a hydraulic shop to get the correct seals. Over all because of it's age rubber parts are probably going to br dried out and can fail.
I would expect between 2 to 6 mpg driving it on the road. but if you need some gravel around the house having your wn truck is invaluable. I could never live without mine as I'm always landscaping or filling spots. If it's in good shape I would buy it.
   / 1975 GMC 6500 dump truck with 366ci gas big block #9
Hydraulic brakes would be a dealbreaker for me; they are absolutely cost prohibitive to repair. Price a brake job, it will make a couple years' insurance look cheap. 366's had a good reputation around here, for a gasser.
   / 1975 GMC 6500 dump truck with 366ci gas big block #10
Let us know what the insurance comes to...
   / 1975 GMC 6500 dump truck with 366ci gas big block #11
I grew up in a family that had a small excavating business. My father had 1970 and 1979 Chevies with the 366 in both. Both trucks were bought new. As I remember, they were both relatively trouble free-I can't remember any engine problems with either one. They both had around 175,000 miles on them when they were replaced.
Dad had 6 yard boxes on both, and routinely hauled 9-10 tons of gravel. He also towed trailers that grossed 12-15 tons moving eqiupment around. The trucks were not fast fully loaded, but they worked well enough for him to make a comfortable living with.
The wheels are usually the split rims, viewed today as dangerous. Hydraulic brakes and a two speed axle and a 5 speed transmission were the usual drivetrain options. If I recall correctly, those trucks got about 5-6 mpg-no matter if they were loaded or empty.
I do remember the 1970 cost $6800 new!!
Will
   / 1975 GMC 6500 dump truck with 366ci gas big block #12
Will
I once owned an IH Fleetstar with a 549 gas engine. It wouldn't have gotten better than 5 MPG on the way down if I had driven it off a cliff.
This silly old dump truck is really on my nerves now. I'd pretty well written it off as "too old". However, being a 1 owner and the owner being a guy who gives a new meaning to "****" on taking care of stuff, I'm really thinking about the old dump.
I didn't think to take any pictures, but other than collector cars, I've never seen a 1975 vehicle in such good condition. Anyway, I made no commitment nor offer of any sort, but I'm going to look at it again on Monday and drive it a bit more. Heck, it's almost too nice for what I want! The glove box has a log book listing every oil change, every fuel fill, every greasing etc. since it was new. The dang floor in it isn't even dirty and I dropped by to see it today unannounced, so it wasn't cleaned for me. He just mentioned to my father this morning that he ought to sell the old thing since it just sits except for his scheduled run times to keep all the seals from drying out. I dunno. I know I can get it for $2500. I'm clearly hoping for less. I guess I'll see. My wife may say that since both barns are completely full, I can't have it. Ooh, that would hurt! :eek:
   / 1975 GMC 6500 dump truck with 366ci gas big block #14
Get the truck. Parts shouldn't be too hard to get for it. A '75 is new compared to the trucks I have. The cab is the same as used in the GM pickups so if you need weatherstripping or windshield gaskets or any other cab parts they should be easy to get.
A '75 qualifies as an antique so you should join the American Truck Historical Society American Truck Historical Society if you buy it. Lots of good info on our discussion forum. There should be an ATHS chapter close to you.
   / 1975 GMC 6500 dump truck with 366ci gas big block #15
If it is as clean as you say, in good working order, and the juice brakes were recently freshened, I say go for it. Even if it is nearly 36 years old. It is probably worth around a grand just in its scrap weight, so a good chunk of the purchase price could be recovered no matter what.
As far as the wife veto, just tell her it followed you home.
   / 1975 GMC 6500 dump truck with 366ci gas big block #16
Here's what Wikipedia says about that engine:
366
The 366 Big block V-8 (6.0 L) gasoline engine was used only in Chevrolet Medium duty trucks and in school buses. It had a bore of 3.935" and a stroke of 3.760". This engine was made from the 1960s until the mid-1990s. The 366 used 3 compression rings on the pistons as it was designed from the very beginning a truck engine. The 366 is a tall deck motor.
Chevrolet Big-Block engine - Wikipedia, the free encyclopedia
With only 29K miles on it, it's hardly broken in yet :).
I just bought a 2004 Isuzu NPR EFI that has the 6.0L (366 cid) V-8 Chevy gas engine in it. The truck is a 14ft stakebed, GVWR=12Klb, 49600 miles. The engine (LQ4) is considered a small block engine nowadays. With the 4-speed 4L80-E automatic tranny and a 4.78 rear end, it moves right along on the freeway. It'll be the transporter for my smaller parade tractors (Farmall Super A, Minneapolis Moline BF).
   / 1975 GMC 6500 dump truck with 366ci gas big block #17
Not sure if you're implying that this is the same motor, but it is not in any way related.
   / 1975 GMC 6500 dump truck with 366ci gas big block #18
If you decide not to get it, I'd probably take it! We've been looking for a good one like that to use at our farm, and the one you are looking at sounds like a nice truck. We've wanting a small dump truck for hauling gravel and dirt.
We've got a 1975 Chevy Bruin with a 427 (tall truck block like the 366 you are looking at), twin screw, 5 x 4 tranny, and well over 200,000 miles, that we use to haul grain to the elevator. Basically it's a big brother to the one you described. It's a real beast, a lot of rust, but does the job. Just had a couple of leaf springs replaced and an air brake pot replaced, along with a couple of rear axle seals and a tuneup earlier this year. That was the first major work we've had to do to it in the 8 years we've had it.
Oh yeah, it gets great mileage! I doubt we get better than 5-6 unloaded, don't even want to talk about it when we're fully loaded. Let's just say we remind ourselves that we aren't using it every day! And for the price we paid for it, we can buy a lot of fuel.
What you have described is well worth the money-buy it and take as good care of it as it sounds like the current owner has, and you will probably sell it down the road and get your money back. Good luck!
GGB
   / 1975 GMC 6500 dump truck with 366ci gas big block #19
Correct. The 6.0L in my Isuzu is part of a different Chevy engine series.
   / 1975 GMC 6500 dump truck with 366ci gas big block #20
One thing about these trucks is they were built tough. Not a pickup truck. If you have land I don't know how you could be without a dump truck. They don't have much in the way of emissions to worry about.
Blue Diamond 103709 (A53317)
Blue Diamond...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
