Ho do you know...
   / Ho do you know...
Not sure about the HST, but as long as you are pulling from the drawbar, I think it will be safe for anything that you can move.
If you hook to the drawbar and it pulls, you are good, If you spin the tires, it is obviously too heavy and needs cut down. But as long as you can move it, I dont think you are going to hurt the tractor.
Yes, herein lies the rub - the Kubota would either spin or pull (no chains), the JD can be in moist ground and not spin or pull (chains). :confused:
   / Ho do you know... #12
Being on moist ground and not spinning or pulling? Is the engine running? Just kidding. I don't see what you're getting at.
   / Ho do you know...
Welcome to our and maybe soon to be your world. LOL be careful it is addictive once you get on here. zman :D
:D
I can see how that happens.
I care more about my tractor than I do my car.
Nice to be able to find info.
:eek:
   / Ho do you know...
Let me try it this way. I'm hooked to a log. I'm at +2k rpm. The rear tires are firmly gripped in good soil. I try going forward - no go.
Does this mean I have exceded the pulling capacity of my tractor?
   / Ho do you know... #15
If the tires are spinning I would say to try less timber or add some weight in your loader if you have one for added traction with the front tires...Being a HST which I have never driven I would make sure I am in Low rge and go from there.
   / Ho do you know... #16
Howdy. I need to back up here I guess - (you mean everybody isn't thinking and knowing about MY new tractor?? Probably not
Tractor is John Deere, 37 Hp, FEL, AG tires loaded, chains.
Terrain is basicly flat. I hook to the drawbar on the TPH to try to get the log butt up out of the dirt. Only cut hardwood.
Don't want to raise any hackels here but I'm thinkin' that Kubota B8200, 19 HP, HST with unusually wide rear tires could pull more than this JD. That's my concern .
Sounds like you have a real nice set up for hauling timber - I'd think you could handle a good sized load with what you describe. I'm finding it hard to believe that you can't move but you're not spinning wheels. Is your clutch slipping or is your HST going into bypass?
-Jim
   / Ho do you know... #17
Howdy folks,
Seems like a nice site. Like to hang around for a bit.
I just traded a Kubota 19 hp for a HST JD 3238.
Guess you mean 3038E rather than 3238?
   / Ho do you know... #18
sounds like you are going into bypass. Try a lower range. Also-if you have never used HST--fully depressing the pedal will put and keep the tractor in bypass when fully loaded in too high of a range. Try barely pressing the HST pedal to keep your rpm's up. Surely someone will explain it better but HST pedal is not like a car gas pedal in terms of power to the ground.
Tornado
   / Ho do you know... #19
A couple people have mentioned that their rims would spin in the tires with loaded tires and not enough pressure. Watch for that.
   / Ho do you know... #20
I agree to make sure you are in low range for this work, if it doesn't move or spin the tires then there is something wrong with the tractor.
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2013 KENWORTH T800 KILL TRUCK & TRAILER (A53843)
2013 KENWORTH T800...
ASSET DESCRIPTIONS & CONDITION (A54607)
ASSET DESCRIPTIONS...
2015 KENWORTH T800 HOT OIL UNIT (A53843)
2015 KENWORTH T800...
New Holland B95 Backhoe (A50490)
New Holland B95...
