My Ride-on Tracked dumper
   / My Ride-on Tracked dumper
Do you have a link?
I will have to look it up when I get a chance tomorrow. While searching I found this new link for a similar setup to mine only much larger but its given me an idea to modify my front tensioner wheel to add a steel wheel to the inside of my track guides.
YouTube - tracked land crawler --PARS
To answer the wear question. My welder and grinder should take care of any wear issues. If something wears down, I will lay a bead of weld and grind it.
Hi Dave,
I have one question with respect to the sprocket drives, and I think of this based on my experience with snowmobiles. Are the sprocket teeth wide enough to prevent excessive wear on the track bars or the sprockets themselves, or, is that a non issue for your application? I've seen the teeth on my sleds wear down more quickly than usual (long term) when I pull a trail groomer or a heavy sleigh (recognizing they are plastic sprockets on a sled riding on steel track clips vs. steel on your machine).
Best of the season to you!
Graham
I would like to add that the sprocket teeth are only 1/2 inch wide and three teeth will be in contact with the track. The reason I did not go wider was that I wanted to drive the sprocket direct off the hydraulic motor with one supporting bearing opposite of the Hydraulic motor. To add a wider sprocket I would have to resort to a short stub shaft and two bearings. I will also have metal guides running inside the track guides just before the sprockets that will ensure the track self centres on the sprocket.
   / My Ride-on Tracked dumper #143
Good morning,
Understanding the width of sprocket issue vs. drive layout, I can appreciate what you're saying about what you have accomplished!
Another machine I've worked with is an Oliver OC-3. The sprockets had one inch wide teeth and over 40 years, they wore out quite a bit, but were still usable, just that the engineered shape of the tooth was sharp on the working face, track pins were relatively less worn. IT had maybe 25 HP and weighed 4500 pounds with the FEL. Your machine is not going to be that heavy and will have less strain on the driveline.
Again, it's been enjoyable to see your project as you post the updates. Happy New Year!
Graham
Great show. I watch where they completely build and test something, then have to tear it down for painting and reassemble everything once again. Having spent most of my adult life offroading, it amazes me that soldiers driving the best off-road vehicles made end up at the receiving end of an IED driving on the road?
   / My Ride-on Tracked dumper #146
I watched the first episode of Howe & Howe tech and when I saw it was going to be another American Chopper clone with back biting, bad scheduling, yelling, etc, etc, etc I decided not to waste my time watching it no matter how cool their vehicles are.
   / My Ride-on Tracked dumper #147
HA HA... I hear you there, but while there are some people like me and probably you who would be happy to sit and watch as they quitely went about grinding, welding, cutting and doing all they do with metal it probably isn't a big enough audience. The "antics and drama" probably brings in more viewers just to see what will happen next. It's the formula that apparently works because all the shows like this of people "doing stuff" are the same and they become popular. It is what it is I guess. :confused:
   / My Ride-on Tracked dumper #148
Agreed - I see that they changed the name of the show now in order to try to make it sound different. It just needs to go away.
   / My Ride-on Tracked dumper #149
Yep, we are in the minority, which is probably why 'Rides' on TLC didn't succeed a few years back. When American Chopper focused more on the bikes, I could tolerate the melodramatic BS; but when the bikes became secondary, I stopped watching. The only reason I watched American Hotrod is that I kept hoping one of the shop slaves would go off the deep end and punch out Bondo-Boyd and his personal turd polisher Duane for the crappy way they treated the employees. Sadly that never happened, or if it did the footage was never aired.
RoGator RG1100C (A51039)
RoGator RG1100C...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2013 MACK GU713 (A50854)
2013 MACK GU713...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
