normde2001
Elite Member
- Joined
- Mar 10, 2002
- Messages
- 4,163
Winston, thanks for the feedback on the Thermostart. I've never needed or used it. It's not currently wired, so I need to make sure the heating element works. I didn't know how much fuel was supposed to come out of the return, and didn't want to have them unattached if/when they started spraying fuel as I tinker. I'll get them connected and investigate the Thermostart.
Norm, I think the overheating troubles will be fixed by the head gasket repair. I like the larger battery, but it's too big to sit in the tray, and it has to tilt one way or the other. I think a slightly smaller battery would fit correctly or at least close enough to not give me interference trouble. It would also save me from having to hack off the battery tray and build a new one. The tractor will be out of commission while I repair the front end components, so if I can't find a shroud to order I'll have to keep the electric fan.
Gary, I need to replace the fan. It would probably be fine, the plastic isn't brittle, but the expense of a new radiator versus a fan blade doesn't make the risk reasonable.
Thanks for the help.
You need the biggest auto type battery that will fit within the width of this holddown clamp and clamp rods, without the electric fan.
