Buying Advice Anyone else thinking about buying a new 1026r?
   / Anyone else thinking about buying a new 1026r? #11
The mid mount D series mowers on these 2020 series machines seems good to me. I have one on my 2320 and have zero trouble. It mows almost as well as the 950 ZTR I have and in my opinion a little better than the X series machines I have used. It cuts smooth and pretty fast and the cut is quite level. With correct set up, this should not be an issue.
John M
i agree with john. the 2305 fit my situation the best. of coarse if i need a bigger loader, i can use one of the ag tractors or the bh. to me the 2000 series look more like tractors than the x series. with the 2305 i can get into some tight spots around the farm. very handy little tractor.
   / Anyone else thinking about buying a new 1026r? #12
I have also been following up on all the info i can get on the 10 series. IMO, the 1023E will be almost like the Kubota BX tractors, similar to the BX2360 mostly with the rigid ROPS and the D120 FEL. The 1026R will be similar to the BX25 with the fold-able ROPS and the H120 FEL. The D120 FEL is pin on where you actually remove the FEL arms and cylinders yet leave the loader posts on the machine and only have a pin on bucket. The H120 FEL will be a quick park unit, similar to the 200CX loader and offer a removable bucket. Both of these loaders have an increased capacity of 25% on the 1 series tractors vs. the 2305. The 1026R will have a little more ground clearance over the 1023E. Both units will have auto hitch, independent deck lift, and the ability to run 7 iron MMMs. JD also moved the fuel tank to under the seat and put the fuel cap on the fender, a much more convenient location compared to the tank under the hood on the 2305.
1023E
22.3Hp
independent Mower lift
Auto connect mower
Auto Hitch
Higher loader lift Capacity
1026R
25.5hp
Auto connect mower
Auto Hitch
I think they will be good units but would be uneasy as these are brand new units and will take some time until possible issues with the units are fixed or resolved. It would be great to hear about it if you purchase one of these units in the future.:thumbsup:
   / Anyone else thinking about buying a new 1026r? #13
Take a look at what John Deere just posted on their web site!
omlvu22338_j0
OldMan
   / Anyone else thinking about buying a new 1026r? #14
check out the engine control system warranty on the new 1000 series in the above operators manual. 2 years 1500 hrs. my 2010 3520 is 5 years 3000 hrs. wonder why the change? bud
   / Anyone else thinking about buying a new 1026r? #16
This is the same as the 2305, looks like the copied it word for word. Read the second paragraph at the start of the warranty "Engine related warranties stated in this manual refer only to emissions related parts and components of your engine. The complete engine warranty, less emission-related parts and components, is provided separately as the Limited Warranty for New John Deere Commercial & Consumer Equipment."
OldMan
   / Anyone else thinking about buying a new 1026r? #17
thats what i am saying. they are only giving warranty on the emission components for 2 yrs. where before it was 5 yrs. bud
   / Anyone else thinking about buying a new 1026r? #18
in checking further i find that the emission components on the new 1000 series & the 2000 series are 2 yrs but yet the 3000 & 4000 series are both 5 years. quite a difference............bud
   / Anyone else thinking about buying a new 1026r? #19
All the specs of the 1023E/1026R.
I am surprised with regards the engines:
1026R engine HP is up v the 2305 (25.5 v 24) but not PTO HP (18 v 18). Why bother?
1023E PTO HP is only 15.3 despite having almost the same engine HP as the 2305 (23.5 v 24).
Does this mean Deere are targeting the 1023E with it's low PTO HP against the Kubota BX1860/ NH Boomer 1020?
While the 1026R is targeted against the Kubota BX2360, MF GC2400 etc.
And Deere are not aiming to have any competitor to the Kubota BX2660 MF GC2600 etc?
Engine
Model 1023E
Manufacturer Yanmar
Model Number 3TNM72
Type Diesel
Gross Horsepower 17.3 kW (23.5 hp)
PTO Horsepower 11.4 kW (15.3 hp)
Cylinders Three
Rated Engine Speed 3200 rpm
Operating Range 1400 - 3370 rpm
Cooling Type Liquid
Oil Filter Standard Single Element
Air Cleaner Dry Type, Two Stage
Model 1026R
Manufacturer Yanmar
Model Number 3TNV76
Type Diesel
Gross Horsepower 18.5 kW (25.2 hp)
PTO Horsepower 13.4 kW (18.0 hp)
Cylinders Three
Cooling Type Liquid
Drivetrain
Type 2 Range Hydrostatic
Number of Speeds Infinite
Mechanical Front Wheel Drive (MFWD) Standard
MFWD Capability All Ranges
MFWD Engagement On The Go
Final Drive Spur Gear
Rear Axle Capacity (Continuous) 715 kg (1576 lb)
Front Axle Capacity (Continuous) 612 kg (1349 lb)
Electrical System
Type 12 Volt
Battery Size 500 Cold Cranking Amps @ -18C (0F)
Alternator 40 amp
Front Wheels and Tires
Standard 18x8.5-10 R4
Optional 18x8.5-10 R3
Rear Wheels and Tires
Standard 26x12.00-12 R4
Optional 26x12.00-12 R3
Front Tire Inflation Pressures (Maximum)
18x8.5-10 R4 152 kPa (22 psi)
18x8.5-10 R3 152 kPa (22 psi)
Rear Tire Inflation Pressures (Maximum)
26x12.00-12 R4 138 kPa (20 psi)
26x12.00-12 R3 138 kPa (20 psi)
Fluid Capacities
Fuel Tank 21.2 L (5.6 gal)
Cooling System 3.7 L (3.9 qt)
Crankcase with Filter 2.7 L (2.9 qt)
Transmission and Hydraulic System 12.3 L (13 qt)
Front Axle 2.8 L (3.0 qt)
Ground Speeds
NOTE: All ground speed calculations shown are with machine equipped with standard 26x12.00-12 R4 rear tires and operated at 3200 engine rpm.
Forward and Reverse - Range High 0-14.6 km/h (0-9.1 mph)
Forward and Reverse - Range Low 0-6.6 km/h (0-4.1 mph)
Dimensions
NOTE: Machine equipped with standard 26x12.00-12 R4 rear tires and 18x8.5-10 R4 front tires.
Wheelbase 1450 mm (57.1 in.)
Overall Length with 3-point Hitch 2605 mm (102.6 in.)
Overall Width 1202 mm (47.3 in.)
Tread Width
Front 918 mm (36.1 in.)
Rear 895 mm (35.2 in.)
Height From Ground
To Top of Hood (R3 Tires) 1061 mm (42 in.)
To Top of ROPS 1968 mm (77.5 in.)
Ground Clearance
Front Axle 195 mm (7.7 in.)
Turning Radius
MFWD Off 2256 mm (88.8 in.)
Weight
Machine equipped with a ROPS, 3-point hitch, standard R4 tires and all fluids
1023E 610 kg (1345 lb)
1026R 655 kg (1444 lb)
3-Point Hitch
Type Limited Category 1
Lift Capacity-61 cm (24 in.) behind link arms 309 kg (681 lb)
Lift Capacity-at link ends 650 kg (1433 lb)
   / Anyone else thinking about buying a new 1026r? #20
Wow. All that redesigning and they still let a woman design the Transmission Range Shift Lever to make geldings out of us. With that wide knob, it looks more painful than the 2305's PTO selector. :(
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
