daman1
Gold Member
Yep all good...How about oil filters? What are everyone's Preferences? Oem, wix, Baldwin, other??
WIX
Baldwin
Fleetguard
Hastings
anything but FRAM!
Yep all good...
WIX
Baldwin
Fleetguard
Hastings
anything but FRAM!
Instead of me typing two pages try a google search,you'll have lots of reading and you can make your own judgment..What's wrong with Fram filters? Just curious...I'm using OEM and I've never had an opportunity to use any of the above filters. Actually I think I've only seen the fleetguard filters but I can't recall where...
Were these canister filters? SG? if not they should easily be able to cross over.depending on the application, they are the 'preferred' or only acceptable choice.. ask old allis owners!
soundguy
Well no technically not according to the ISO 4548-12 for particle test FRAMs best designed filter the Extended Guard or next the Tough Guard is 97-99% @ 20 microns. and that's ONLY on equivalent PN's PH8A, 3387A and 6607Gale Hawkins said:Fram makes different price range of filters and they all seem to work quite well but the Tough Guard will spec out like a Mobile One filter (99%).:thumbsup:
The Mobil is 99.2% @20 percent efficiency rating (under SAE J1858 Multi-Pass Efficiency Test), across the board all PN's so splitting hairs i know but just saying..
Fram does make a high quality filter that stands above the rest of their line, and it's the Extended Guard. Even Fram haters have admitted that it's a quality filter, and wouldn't hesitate to use it themselves.
It's a little too expensive for my tastes, though, since I change my oil at 3k-5k miles.
I usually buy the Wix filters for my car & tractor and Motorcraft for my F-150.
Wix can be bought at many auto parts stores. I get mine at O'Reillys.
daman1 maybe you should reread the Fram site info.
Tough Guard is is their top filtering filter (99%)
Chris you should check out Fleetfilter.com for WIX,Napa golds you would get a nice discount if you do that many services and know you'll be using a quality built filter.I do about 75 oil changes a year and have been doing so since 1989. I have been buying my filters on line 100 or so at a time.
#edit# ..i did a search here and read up the AC thing you mentioned and cant for the life of me under stand why a more restrictive filter would be needed to build proper operating oil pressure but just the contrary, bad engine design, engine wore out? if bearing clearances are right and pump is working i don't see why.
But anyway..any of todays filters are of a cellulose paper design or a Synthetic glass media or glass micro fiber media in the synthetic version filters and WILL NOT hamper oil flow in any way on a modern engine IF crossed to the right PN, that manufacture in question would not want that type of liability and has done intensive testing on that filter. Most any filter today will have flow,thread design and bypass specs so you can compare them to your OEM.
i'm not arguing with you just trying to under stand your floss media comment,it's hard to believe FRAM would be the only maker of filter for that application.
so yes any filter that will screw on with matching specs will work
Like i said i googled it and didn't find much on the web about this filter design, tho this tractor is waay before my time working with this type situations and maintaining high dollar equipment is not so we agree to disagree.owning an allis I can tell you it's a wide topic of discussion. on the allis board at the 'unofficial' allis site, any time someone come son with a low oil pressure issue we ask them if they just changed oil and filter. 99% of the time they did and used a non floss filter..
It's not an uncommon problem if you are the owner of a few specific models of tractor.
last I heard there is a distribuitor making a 'like kind' filter that will work.. but is special and quantity order.. vs just getting the fram filter which is available.
kind of like saying any stainless steel bolt of the correct size and thread pitch can be used to replace this stainless steel bolt .. of 'certain' size and pitch.
that's my point.. it's dern hard to find a filter made the same, thus an appropriate match...
soundguy
Explain this statement? i guess i don't under stand your logic then.kind of like saying any stainless steel bolt of the correct size and thread pitch can be used to replace this stainless steel bolt .. of 'certain' size and pitch.
