Row hipper/builder manufacturers
   / Row hipper/builder manufacturers #21
I built mine,I purchased a TSC cultivator and added the 16 inch disc from Agri-supply;a little scrap steel.Mine bolts on,it can be removed to use just the cultivator.To answer the question wat a hiller is;it forms the rows for a garden(raised bed).
I sent you a Private Message...
   / Row hipper/builder manufacturers #22
STIMW; I know it's been almost 2 years since this post but I would like to buy one of these cultivaters......or a two or three disk one.... anyone know where???? Are you still around?
Rob rwillis757@yahoo.com
   / Row hipper/builder manufacturers #23
Post number 9, in this thread............that's all you need.
I'm trying to be careful where I post, don't want to step on Ken.
Cultivator is from TSC, disc hilliers can be obtained here: http://www.agrisupply.com/category....E_c_A_sb_E_0_A_action_E_showall_A_c_E_4500013
   / Row hipper/builder manufacturers #24
Don, did you get your discs turned around? If you have, let us know how it works compared to before. I have a cultivator similar to yours and I like the way you can hill and plow out your tracks at the same time, with my hiller, I leave about half of my track on each side and I have to knock that out with my BCS.
   / Row hipper/builder manufacturers #25
I'm in the middle of putting one together too. I'm wondering why you'd want to break up the tire tracks (not knowing much about gardening), seems like it would grow less weeds there if it was compacted in the tracks..
   / Row hipper/builder manufacturers #26
Jake98
I have found it is better to pull up the weeds rather than just run over them.One thing I forgot to say is:I also added peanut sweeps to my cultivator..just adds a little more area.Also from AGRI Supply,note some welding required.
Check out www.bayougardener.com,lots of good info on gardening.
   / Row hipper/builder manufacturers #27
Jake98
Thanks, will do.
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Giyi 72" Grapple (A53316)
Giyi 72" Grapple...
Decorative Mermaid Statue (A55758)
Decorative Mermaid...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
CFG Industrial H15R (A53316)
CFG Industrial...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
