No, even if only one tire is spinning the speed of the tire does not double.
The speed of the tire (one or both) is limited by the engine rpm and gear ratio. Theoretical top speed of the car is the same as the max speed the one tire will spin. Actual top speed of course is less due to friction, air resistance, etc.
K7LN is correct. Don't confuse a planetary unit with a differential. You might want to look into that a little more.
See I am not full of crap:laughing::laughing: Well actually I am full of crap most of the time.:laughing: but the twice speed thing is for real, if you one wheel is totally stopped and the other is spinning on an open diffy. that is why in your owners manual of your car, they caution against "excessive" wheel spin as it is hard on your spinning tires to go that fast, as you can easily go over the speed rating of your tire, and it can fly apart. I have never actually seen one fly apart from all that smoke rolling off of it, but I suppose it could happen. But I remember sitting perfectly still and seeing 120 MPH on the speedo. So I guess one tire was going about 240 mph, as there was only 1 black mark on the road.
James K0UA
I hate to burst your bubble, but what you wrote makes no sense. The speedo is reading the speed of the tire, the spider gears are not multipliers. One wheel spinning is just that, one wheel spinning -- not spinning 2x the normal speed because only one is spinning. Watch the video, it will make it all clear.
Owners manuals tell you not to spin the wheels because "bad expensive things" happen when traction is found. You will also be much less in control of the vehicle while spinning and if stuck you will just dig down making it harder to get out.
I'm sure that was a fake video. Not possible to create enough friction to catch a car on fire from an ice burn out.
A typical open diff has four spider gears. The two splined onto the axles are considered sun gears and the two pinned to the carrier are the planetaries.
The planetaries are pinned to the case by the cross shaft, and when you abuse an open diff with one wheel peels, the gears will gall to the cross shaft, effectively locking the diff.
:thumbsup:
Sorry, dont think so.. the speedo is reading the speed of the transmission, not the tire, the speedo gear is in the rear end of the transmission. so if it is reading 120, the transmission is running at the RPM that would make the tires go 120, after it goes thru the differential, and going in a straight line, now, the spyder gears are not turning, on their shafts, they are pushing the side bevel gears ok.. So now if you stop one wheel the spyder gears are now rotating on their shafts as well as still pushing "sideways" from the differential frame, which is attached to the main ring gear solidly by bolts. so you have the rotational speed of the differential frame pushing at 120 plus the spyder gears rotation against the now "dead" tire causing the speed to double.. the spinning tire is now going 240 MPH. thats my story and I am sticking to it.
James K0UA
My first experience was in 1964 when I purchased a posi unit and put it in my 1964 Chevelle. The unit cost me a grand total of $44 plus a couple bucks for 2 quarts of the good lube that was made in those days. Let's hear it for inflation. GM brought out the posi unit in 1957, mainly for the highly successful Corvette and the new fuel injection systems that came out that same year for Chevy and Pontiac.
James K0UA
Sounds to me that's why it says it in your own's manual. In my owners manual, they substituted a paragraph about bailing out safely if the car gets possessed by an evil spirit.
I never was much of a hot-rodder, so if it says that in my manual, it's to keep me from spilling my coffee on my shirt if a tire spins a cow patty.
Edit: Direct quote from my manual: "If you feel there is a danger the wheel will disintegrate, and you are sober, the HAL 9000 engine control module is self-aware, and despite advice from the HAL 9000 unit, it is time to exit the vehicle, regardless of speed."
I really hadn't thought much about whether any tractors have limited slip differentials, since my Kubotas had the common differential lock pedal. But going back to the middle ages when we had a 1940 John Deere L, I can remember a number of times I tried pulling something it couldn't move, but the rear tires would dig holes in the ground and they never spun together. One would turn aways, stop, and the other one would turn a short distance, and stop; just back and forth, so I assume it must have had some kind of limited slip. And of course, the tractor would rock back and forth when it was doing it.
With an open differential the tire with the least amount of traction will spin. I think what may have been happening to you is that after one tire had been spinning for a bit, it would gain some traction and stop spinning. The other tire would start to spin because it now had less traction than the first tire.
This process then continued.
be hard to have the lack of traction equal and keep it that way
This has been a great topic. The only way it would be better is if you went out and did it again just to film it for us.
