Tractor or Truck for plowing?
   / Tractor or Truck for plowing? #41
As to auto transmissions on pickups and plowing, one idea explained to me was that they are damaged when the driver shifts from forward to reverse without giving the truck time to come to a stop. According to this person, that causes very high pressures inside the auto trans.
I have no idea, but if that's so it could explain why some go through a transmission in a couple years and others don't ever need a rebuild.
Dave.
My wife's BIL says the same thing, and he does commercial plowing. He lives in New Hampshire, so I'm sure he gets his share of snow plowing.
   / Tractor or Truck for plowing? #42
That is the main reason trannys are damaged while plowing. Because people get in a hurry and dont think about the equipment. But in reality, it has NOTHING to do with plowing itself. If you shift any vehichle from F to R without stopping completely, it is going to be hard on the tranny. Not just trucks with plows.
   / Tractor or Truck for plowing? #43
Granted, it's just that plowing leads to a lot of back and forth travel. I threw it out there for two reasons: to see if it's valid :), and if it is, to help people avoid expensive repairs. Not blaming the plow itself.
Dave.
   / Tractor or Truck for plowing? #44
Dave.
Yes it is valid on MOST plow trucks running aroung.
On the newer ones, I am not sure. A lot of the newer electronic trannies dont let it shift from F to R if you are moving even if you hit the lever. But I don't know how sensitive that is. Just a slight roll???? I dont know. Because it was mainly designed for situations like driving down the highway and accidently hitting the lever.
   / Tractor or Truck for plowing? #45
Well, how much would you figure that set-up to be??
I am figuring about $30k per NEW plow truck. That is about what they cost for just a basic stripped down 3/4 ton truck/plow combo.
And by manuveribility I am meaning the ability to get into tight spots. Like back-dragging between a couple of parked cars. That 14-16' box just wouldn't fit.
I would figure closer to $40K per plow truck set up. Around here an 8 foot basic blade from Western, Fisher, Sno Way, Boss or Blizzard are running between $4500 and $5000, and that is just a basic blade, not a vee, or wing plow. For a brand new truck, basic 4x4, regular cab, 3/4 or 1 ton they seem to be going for at least $35K with discounting, but no rebates around here. It also seems that you can only get a significant rebate towards the end of the year when all the old stock needs to be cleared out. Since nobody wants a stripped down, regular cab 4x4, the dealers don't stock them, they only special order them so there aren't any to close out at the end of the year. So you can't get as big of a discount on them as you can with some of the better equipped vehicles. At least this has been my experience in this area of the country. Also that $40K estimate is for a gas engine, most plow guys in this area prefer to run diesels if they are running 3/4 ton or up trucks. Even the thirstiest new 6.4 liter diesels still do better on fuel economy than the smaller gas engines in this area based on my experience. You'd have to add at least $5K for a diesel.
   / Tractor or Truck for plowing? #46
I will also add that two trucks with wings can push almost as much snow as that 1 push box on that tractor..
:laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing::laughing:
No offense but you obviosuly have no idea how much snow that tractor is moving
   / Tractor or Truck for plowing? #47
Under $200k. I plow with diesels so I guess my figures for trucks was a little higher than yours.
The beauty of a plow like that is it can still back drag well since the wings fold out to make a straight blade. No it won't fit in two stalls but it doesn't need to.
   / Tractor or Truck for plowing? #48
I will also add that two trucks with wings can push almost as much snow as that 1 push box on that tractor. Provided the operators are experienced.
We had an opportunity to do so thursday night into yesterday. Was out for 14 hours plowing some of the Columbus schools.
Two trucks with wings, angle the blades toward eachother, and lock wings. It is like a big 15' V-plow. Very nice when in a lot that requires the snow to be moved all the way to one end. Windrow everything into big runs and then lock plows and make a big push. Then windrow the trail-offs back up and repete.
Two plows plowing in conjuction like this can easily moove 4-5 times more snow than just a single truck with a V-plow or winged plow. We do it quite often. And it's a lot of fun:thumbsup: Just dont do it with a rookie. Cause it is easy for one truck to loose traction and slide into eachother.
Two truck forming a V still can't move anything like that can. The moldboard is 5" high and the end plates are 4' long IIRC.
   / Tractor or Truck for plowing? #49
Diesels arent "required" to plow snow. A 3/4ton diesel can NOT move any more snow than a gasser equiped with the same blade.
And it may not need to fit into tight areas on that lot, but most of us plow guys run into tight situations daily that that thing just would not fit into.
O' yea I have a really good Idea.
Assuming you ment 5' high instead of 5", that is still exaggerationg it a bit.
It is a 16' Horst pusher. 5500 series. That is 3.5' tall moldboard (42") and only 3' wings.
HORST WELDING | HLA >> 5500 SERIES
So two trucks locking wings and forming a 16' vee plow with 30" moldboards and outer wings doesnt come close:confused::confused::confused: It may not be quite as much as that, but you obviously havent seen it done before. Because it is way more than you give it credit for judging by your response. And the trucks can maintain a faster ground speed as well.
Dont get me wrong. That is an impressive machine. I mean no disrespect to it what so ever. I am only pointing out the fact that the money spent on that could buy enough trucks to out-work it.
But for that matter as well, $200k will buy a lot of shovels that will out work it or the trucks on a dollar basis. At least until you have to pay 20,000 employees hourly for operating those shovels:laughing:
   / Tractor or Truck for plowing? #50
I would use a truck for driveways, you just cant travel fast enough between sites. A Big tractor/loader for big parking lots, you just cant stack the snow high enough and also a truck/small tractor/skidster for detail work during business hours. I use my MX 5100 HST with a bucket to plow my shop and personal driveway since they are 3 door apart (looking to fabricate a plow soon).
   / Tractor or Truck for plowing? #51
I think that that is the ultimate reason behind using big equipment for large scale snow removal. Let's say that 3 trucks would equal the capabilities of that one tractor. With the tractor, you're only paying one operator instead of 3. If you're mostly doing driveways and smaller parking lots then you need the speed and versatility of having a few pickup truck plows, as you don't need to dedicate such an expensive piece of a equipment to something that doesn't need such an elaborate setup to complete. By the same token, for doing large parking lots, one guy on that tractor and plow can be left alone to do the lot by himself, possibly needing a pickup in spots for certain clean ups. Nowadays, equipment costs are generally cheaper than labor costs.
   / Tractor or Truck for plowing? #52
Just for kicks, I crunched some numbers. (must me my love of math or something:D)
But the 16' pusher on that tractor, with 42" board and 36" wings equates to 6.22 cubic yards of material if you draw a straight line across the wing tips.
It will obviously move more snow due to what is piled up in front, but that is hard to calculate.
Two 7.5' plows, with 1' wing extentions like mine, and only a 26" tall moldboard like the ST or lighter duty plows, angled at 30* (max on mine) will hold a volume of 5.22 yards if a straight line is drawn across the wing tips.
Again, they will obviously move more because the main pile of snow will extend beyond and above this area. A little more so on the taller push box, but the #'s are a little closer than one may think.
And if using 8' plows with 28" moldboards and same 1' wings, that number ups to 6.38 yards.
Either way it is still a lot more snow than a person may think two trucks can push. We have pushed some impressive piles.
The total will untimatally depend on what the plow sizes are of the two locked plows. My particular plow is a 7.5' 26" variety. But I have locked up with a 9'2"vee with wings, a 7' snowway with a short moldboard and no wings, and everything inbetween. But when having to run snow all the way to the end of a long aisle, what would normally take just me 10-12 pushes can be done in about 2 by hooking up. But in this game, it is all about efficency. Next time out, I'll try to get some pictures of us in action.:D
I used my 'new to me' tractor (L4610) the other day in a fairly light but very slippery base snow to plow my driveway as well as some neighbors. I know the first thing I need to do is fill the tires and add some chains because I couldn't get traction for the life of me with a full bucket of snow.
I was just playing around and having fun so no big deal but I was pretty surprised at little snow I could push before I started spinning. This just goes to show how important weight is when plowing.
I think with another 1200lbs or so of Ribguard in the tires and a box blade on the back I'll do a whole lot better.
Also, I think overall a diesel truck vs. gas truck will plow better/more snow in the same conditions simply because of the added weight of the deisel engine. More weight (with all other variables the same) equals better traction.
   / Tractor or Truck for plowing? #54
Yes, weight does equal traction, but given the relatively small amount of weight difference in the grand scheme of things, their are other factors that affect it more.
I am not sure what the weight diff is, but it cant be more than 400-500lbs at most. And what about a BB like the V-10's.
But more important than engine weight are bed weight (ballast, salt box, whatever), tire type, and posi/LS rear vs open diff.
If I have 1000lbs in the bed, LS diff, and the diesel has the same ballast, same LS diff, and same tires, then yes probabally. But the traction difference would hardly be noticable.
Now if the diesel has an open diff and no weight, and a small block gasser has ballast, LS, and better tires, then my money is on the gasser.
   / Tractor or Truck for plowing? #55
Wanna bet? :)
Yes I have seen it done and have done it.
Two trucks will push alot of snow but lets get real. If you tried to push what that tractor is pushing you would just slide of the pile and destroy trucks trying. That tractor will push it all day and ask for more. Dollar for dollar that tractor will do more then the equivalent in trucks.
ps I never said diesels are required but do we want to compare fuel consumption of a few gas trucks to the tractor?
   / Tractor or Truck for plowing? #56
Wanna bet? :)
Sure I do. There are many other more important factors that determine how much a truck can plow other than the little bit of added weight of the diesel motor. But I do agree that All other things being equal (tires, ballast, rear end) that the diesel will have a SLIGHT advantage. I have out-pushed pleanty of diesels. Because they were un-ballasted and probabally open diff. I have LS diff, good tires, and ~1000lbs in the bed. Now if a diesel were set up like that, they would have the edge.
Again, all I am trying to point out is that there are other more important factors to consider.
Yes, that tractor is pushing a LOT of snow. All I am saying is that the trucks will come darn close. AND they have a faster ground speed. And a lot depends on the snow type. Sure, a wet heavy snow is going to give the trucks problems, but I would also be willing to be a good heavy snow would also give that tractor a few issues too. I have seen a heavy snow give a 4x4 JD 410 backhoe issues with a 12' box that was shorter and smaller sides. And a the 4x4 410 weighs within a few thousand lbs of that mx255. But a lighter snow, we have locked plows and pushed until the snow was ~8' in front of the blades piling up ~ 3.5-4' high and comming back over the plows before and no issues sliding into each other.
And even if you like the diesels, set them up with 9'2" v plows AND wings, and I'd still take 4 of them for the money over that tractor for speed, But depending on how much per HR you can get for the tractor vs the trucks, and what you pay employees, the tractor may be cheaper in the long haul to operate. But too many unknowns and variables to figure the cost.
   / Tractor or Truck for plowing? #57
hmmmm. this post just gets me more and more confused what i need for my new tractor......the more i study the more confused i get. I have a new Kioti DK45SE HST CAB tractor and plan on taking care of between 5-10 miles of gravel roads next year. (will start with 5 and see what happens). It all flat and located in north Idaho. we get roughly 110" of snow a year. usually 4-6 inches at a time, but 2 years ago we got 36" over night. its usually semi dry to wet snow. Currently i take care of my 30 acres with my old JD870 and 60" rear snowblower. Ill be getting either a rear push or a rear pull style 84" snowblower for the new tractor (havnt decided yet) and im thinking of getting a front 84" snow blade. Since the tractor tops out at 16 MPH, i don't see the blade throwing the snow very far. But ive watched some youtube videos of front mounted snowblowers in operation, and they seem to be going real slow. so if i were to spend the $$$$$$ for a loader mounted front blower....doing 5-10 miles of roads....it would take a LONG time to blow them, or so it seams. has anyone used a front mount 84" or so snowblower in this forum to tell me how fast you can travel (on average). and can a front blade move snow at a better rate????. Im afraid of what a rear pull snowblower would do in a heavier snow. i wish i had lots of $$$$$,. then i would buy all and use them as necessary. oh....as son as the new tractor arrives (2-3 days) ill post some pics.....so far al i have is one from the lot, with ag tires on it. their switching those for r4 tires.
   / Tractor or Truck for plowing? #58
I think a tractor is the wrong thing for that much road. You need a dump truck or at the very least a SRW diesel pickup.
I run a 7.5' snow plow on the front of my tractor and its 10 times faster than a blower for snows less than 12". The key is to keep up with it.
Chris
   / Tractor or Truck for plowing? #59
Chris
I agree, but it doesnt HAVE to be a diesel. A gasser would do just fine.
   / Tractor or Truck for plowing? #60
Chris
im only concerned that id wreck my truck. everyone i know that plows with a truck is repairing the transmission all the time. id hate to wreck my truck. but i understand what your saying. thank you
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
FUEL CELL (A58214)
FUEL CELL (A58214)
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
