These used yanmar tillers that are sold by the dealers refurbished as well??
Also not sure if I understand what link I need to make sure I get? What if this one does not have it??
I don't think they need refurbishing. just verify there is a full set of tines. It probably needs a change of the gear oil (90 wt) and repack of the lower bearing on the offside (wheel bearing or lube grease) to prepare it for service.
Here are some photos I've accumulated:
I bought the cheapest tiller
among 20 or so and got a better price because it needed a new $5 input shaft seal, but the leak there is only a stain, not a drip, so I haven't replaced it.
Here's a picture the first time I attached it. I found the driveshaft too short, apparently shortened to allow a slip-clutch or ratcheting over-run clutch. I went back and the dealer gave me a shaft extender (not shown here). My point in posting this is to show the special top link in use. This is the same device as shown in Carey's photo a couple of posts above this one. Note
how close the tiller is to the tires; the special top link is essential. And here is
a photo I copied from someone's post here (Carey??) again showing the two-part top link you need. I wish my equipment were as clean as that!
In summary - be sure to get the correct special top link for your tractor, and the special short driveshaft. Either is very expensive to obtain separately and you can't use the tiller without them.
More pictures I found, just for fun:
first time I tried the tiller. I tilled @ 540 rpm for a few feet, then put the pto in Hi gear, 1000 rpm, for a few more feet. I decided Hi should only be used for a final pass, it hammers too much on a first pass like this.
Finally, the
same tiller (RS1400) now attached to my YM186D. The little tractor will barely pull it, I don't recommend this combination to get any real work done. RS1400 specifically declares on its label that it is intended for YM2000. (which is the same as my US-version YM240).
Hope I'm not boring everyone with all this longwindedness. I'm stuck in town and bored to death - which is probably obvious.
