Weight on a yanmar 4ft tiller
   / Weight on a yanmar 4ft tiller #12
I'd be surprised if the RS1201 (48" wide) that came with my 1510 was much more than 300lbs. It would be a bit awkward to get in the back of an SUV though.
   / Weight on a yanmar 4ft tiller #13
I will be down there on business so the mileage is not a big thing (I work 50 miles from where it is)....but I don't want to haul my trailer that far.
Maybe the *business* will rent you a truck for the trip? Personally, I wouldn't want to deal with a small trailer for that long of a trip either.
Keith
   / Weight on a yanmar 4ft tiller #14
These tillers aren't real heavy. This RS1400 is noticeably lighter than my back blade, which is supposed to weigh 450 lbs.
But the shape is awkward. It would take very careful work with a beam pole and guy ropes to set and remove it from a SUV without tearing up the car. And the loaded weight would be deadly in a crash.
These used yanmar tillers that are sold by the dealers refurbished as well??
Also not sure if I understand what link I need to make sure I get? What if this one does not have it??
Thanks Guys.... California's comment about it being deadly in the vehicle was the final straw....I chain down all my equipment to my trailer for this reason....so trailer it will be.
   / Weight on a yanmar 4ft tiller #16
New tines and everything working Properly from the site I posted. And the top link is almost a must. :cool:
Carey
   / Weight on a yanmar 4ft tiller #17
The mount & link Cary has posted give general shape but these mounts and upper links have changed somewhat over the yrs and can vary with tractor and tiller. My mount has a tag on it saying which tractor it worked with PTO shafts are quite short if using this mount. Yanmar had their tillers mounted VERY close to rear tires when tiller was in the down position thus requiring the special mount and upper link that caused the tiller to pivot as it was raised so it would miss the rear tires.
Here's a pic of mine. If you look closely you can see the mount and upper link. I no longer use these as I went with a quick mount hitch.
Hitch setup can vary with tiller model. Some early ones had 2pt hitch and later 3pt hitches. And Yanmar had for a while a quick mount hitch and the one I saw was unique to the tiller. Best I can say is, make sure tractor, mount and tiller are all compatible with each other. Don't want to get back home and find something not working.
Wish there were a knowledgeable dealer jumping in here that could offer better advise.
   / Weight on a yanmar 4ft tiller #18
I don't think they need refurbishing. just verify there is a full set of tines. It probably needs a change of the gear oil (90 wt) and repack of the lower bearing on the offside (wheel bearing or lube grease) to prepare it for service.
Here are some photos I've accumulated:
I bought the cheapest tiller among 20 or so and got a better price because it needed a new $5 input shaft seal, but the leak there is only a stain, not a drip, so I haven't replaced it. Here's a picture the first time I attached it. I found the driveshaft too short, apparently shortened to allow a slip-clutch or ratcheting over-run clutch. I went back and the dealer gave me a shaft extender (not shown here). My point in posting this is to show the special top link in use. This is the same device as shown in Carey's photo a couple of posts above this one. Note how close the tiller is to the tires; the special top link is essential. And here is a photo I copied from someone's post here (Carey??) again showing the two-part top link you need. I wish my equipment were as clean as that!
In summary - be sure to get the correct special top link for your tractor, and the special short driveshaft. Either is very expensive to obtain separately and you can't use the tiller without them.
More pictures I found, just for fun: first time I tried the tiller. I tilled @ 540 rpm for a few feet, then put the pto in Hi gear, 1000 rpm, for a few more feet. I decided Hi should only be used for a final pass, it hammers too much on a first pass like this.
Finally, the same tiller (RS1400) now attached to my YM186D. The little tractor will barely pull it, I don't recommend this combination to get any real work done. RS1400 specifically declares on its label that it is intended for YM2000. (which is the same as my US-version YM240).
Hope I'm not boring everyone with all this longwindedness. I'm stuck in town and bored to death - which is probably obvious. :D
   / Weight on a yanmar 4ft tiller #19
Should work. Should be about 400 #, a 4 wheel dolly, or 2, and set of ramps or equivalent. I hauled a Simplicity 4' riding mower, (about 400 #), in the back of my '99 Pontiac Montana for 800 miles, didn't even know it was there. Winch it up the ramps with a come-along hooked to a front seat if necessary.
   / Weight on a yanmar 4ft tiller #20
The top-link I had to get separately was $35. So its not necessarily a deal breaker IMO. You might call Fredricks or Spalding ahead of time to make sure they have one if you need one. I just got mine yesterday and I can't wait to check the fit this weekend. It looks just like Careys pic of it. If you need a driveshaft...I'm not sure what that would cost.
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
Kubota L4701 (A53317)
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
John Deere 5103 (A53317)
John Deere 5103...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
