TSC boxblade
   / TSC boxblade #11
With a front mount snow blower and "soon" a Herd sand spreader for the rear I have no need for a box blade in the winter time. Actually the only reason I don't have the spreader now is because I never got around to filling the tires so I have a rear weight on the tractor.
Ahhh...I hear that, really hard to beat snow blower out front..:thumbsup:
   / TSC boxblade #12
I have a United 672 box blade. Seems well built. I have an 820' gravel drive with a couple of steep parts that wash in heavy rain, so I use the blade a lot to keep it smooth. I've also used the rippers in ways you might expect -- loosening compacted soil, tearing up root networks, and so on.
I have no complaints with the United blade.
Jay
   / TSC boxblade #13
Jay
Everything Attachments (who is a user on here) sells United.
   / TSC boxblade #14
If you compare the photos of the TSC and United box blades note that the TSC blade has two angled flat bar braces from the top link point to the back of the box. The United blade has one brace going straight back. I have a TSC blade and bent these braces like a pretzel pushing back some dirt that I just dropped from the box. I repaired it by installing a brace similar to the United straight back out of 2 x 2 tube steel. Now it works like a champ.:)
IMHO United box blade construction is stronger. If its a toss up between the two, get the United.
CountyLine Box Blade, 5 ft. - 2131645 | Tractor Supply Company
United 560HD Heavy Duty Box Blade 60"
My TSC box blade after repair
   / TSC boxblade #15
Good points. Perhaps the Country Line BBs are the regular duty Tarters, not the HD. I have the heavy duty Tarter and it has a big square tube going to the back, as well as very wide plates forming the side braces. It's very sturdy.
Photo Large
The United looks like it has a tubular brace with flattened ends at the attach points. The ends look like weak points compared to square tubing cut at the proper angles to match the surfaces.
Just an observation.
Joe
   / TSC boxblade #16
Found a picture with a slightly better view of the braces.
Joe
   / TSC boxblade
It does look like the countryline is the standard duty blade. I really don't like the idea of those supports being bolted on.
   / TSC boxblade #18
Joe
Yes, that is how it should be built.:thumbsup: That looks to be a nice box blade.
   / TSC boxblade #19
I bought my 5' King Kutter at TSC about 4 years ago. I am very happy with it. It is listed as 415 lbs. on the King Kutter web site.
   / TSC boxblade #20
I looked at the TSC countyline box blade and then bought the United heavy duty box blade from everything attachments. The Countyline wasn't built as well and was about 60$ more, not including tax. The lower link attaching pins are supported on both sides (United BB) instead of just bolted on (TSC BB). Shortly after I bought it, one of the scarifier teeth came off. I sent an email to them and I had 2 new teeth in a couple days - free of charge. Nice folks to work with and good quality equipment. I have the 48" BB and pull it with a sub-compact.
2016 Dodge Ram 5500 Lube Truck (A55788)
2016 Dodge Ram...
33'x25' Double Garage Steel Barn Shed (A53316)
33'x25' Double...
PETERBILT DUMP TRUCK (A52706)
PETERBILT DUMP...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A55788)
2013 East...
