What's a good snake load?
   / What's a good snake load? #31
I cut alot of wood while living in Missouri. I saw copperheads on a daily basis. I carried my S&W 357 for a while, but switched to a Moss 500 pump 12ga with a pistol grip. Best snake gun I've ever used. The two in the bottom pic was under a tree that I had already made several cuts in. The second one lost his head and several inches in one shot.
   / What's a good snake load? #32
There you go, hard to beat an old Mossberg 500, for a tough inexpensive utility gun. I have several. Best medicine for anything that walks or slithers:laughing:
James K0UA
   / What's a good snake load? #33
I don't shoot too many snakes in PA but once there was a big black snake high up in the trees I shot with my 410 10 Inch barrel T/C Contender and I never knew there was so much blood that could come raining down. Dropped immediately.
This makes and excellant tractor firearm but is only a single shot so make it count!
I don't kill any "friendly" snakes. But Rattlers aren't friendly and they are on my list.
NO.1 is a Square Point Shovel, 2 a garden hoe, 3 anything handy, rock, stick or ?? Haven't shot a snake since I was a kid.
   / What's a good snake load? #34
What kind of snakes are you guys shooting that need more "stopping power" than a .22 can deliver? The comment about a .38/.357 shotshell backed up by hollow points just made me crack up.
Now, I realize that the higher caliber shotshell will carry more shot, thus making a better chance of a lethal first shot, and the same with 12 ga/410 shotgun, because then you don't have to be as accurate when dealing with you legless adversary. But the idea of needing to use a .357 hollowpoint or a .45 acp to kill a snake.....if it takes that kill a snake, it's gonna have to bite me in the backside, 'cause I'm running away.
I also realize that carrying a larger caliber is advantageous in case you need the firearm for dealing with a coyote/cougar/bobcat/felon/feral pig/terrorist/Rainbow Vacuum Salesman/skunk/opossum/etc., so I certainly respect that option. In that view, the revolver with shot followed by hollowpoints makes alot more sense.
And I also agree with a previous poster - I haven't shot (at) a snake in years - I usually just kill them with shovel/hoe/stick/rock/etc., including the copperheads that I found at the pond in the summer.
Good luck and take care.
   / What's a good snake load? #35
I think it is the fun factor. As long as they are being safe about it, no big deal. I think it would be a blast to chase a snake around with my AR-15. Sure, the 12ga would get it one shot, but not quite as much fun.
   / What's a good snake load? #36
My preference is the shovel as well. But at a certain point/size, using the shovel gets to be a bit risky. Strike range on a rattler is 75% of body length and 3-5 ft rattlers is not uncommon in my part of the country. Last year, the police did in a 6-7 ft one in a lady's back yard not 3 miles from me (google rattlesnake and Manor, TX to see pics and news story).
Last Sept, I had to use the single shot 410 on this guy (see pic) who was 10 ft from the front door. A great animal and hated to do him in, but 3 ft long and at the front door was too much.
   / What's a good snake load? #38
If I already have a .45 on me, why go find a shovel, .22, hoe, stick, etc.? Shovels are hard to find a holster for.
   / What's a good snake load? #40
Dont want to turn this into a gun thread but... I have NEVER had any BAD luck with returning guns to the factory.. I have sent several back-from different Manufactures-- and all where really good on fixing the problem and fixing it right.. Ruger is the one that really fixed a vaquero I sent back and WOW it is really a good shooter now. I cant say that about to many other equipment manufactures..
AndyG
Nothing wrong with that.:)
Same general experiences here.
I sent a Walther PPK back and they sent me a new gun.
I sent a S&W 6906 back and it was quickly repaired.
2005 Ford F-750 Truck, VIN # 3FRXF75R05V113199 (A53422)
2005 Ford F-750...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2018 Freightliner M2 106 Altec LR756 Forestry Bucket Truck (A52377)
2018 Freightliner...
CATERPILLAR 302.7 CR EXCAVATOR (A52705)
CATERPILLAR 302.7...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
