My Carryall Project
   / My Carryall Project
Nice project. If you wanted to haul firewood or whatever it would be easy enough to prefab sides that go on + off.
Looks good though!
Thanks! I didn't put sides on it since I have a FEL for loads like that...:)
CTF - were you able to get one of the Cat 1 pins to fit? I couldn't find one that did when I went to buy one of these? Love the project.
Dana
Yes, the short cat. 1 pin fit but it was a little close. The medium one is a little long, but that's what I'm using...I bought one of each just to be safe...;)
   / My Carryall Project #43
Nice job.
I built my own weight box for my BX. The shape is pretty close to the Kubota box, but I modified it quite a bit. I used expanded metal grating for the bottom so it won't hold water and added some brackets on the backside of it to hold a shovel, a pitchfork and a rake.
I've got a small tool box in there and as of yet, have never actually used it as a weight box. It's only been used as a carryall.
Here is the latest pic of the carryall. I moved the SMV sign to the side.
   / My Carryall Project #46
Here are some "In Progress" photos:
I have to ask - what do you use this for? I am thinking I could carry things in the scoop and leave my blade, tiller, or whatever hanging on the back. I could see it used for firewood to get it out of the tree lot but what else do you use it for? Just curious.
I use it for hauling around all kinds of stuff I don't want to put in the loader bucket. The only other rear attachment we have is the backhoe, and with it's size I don't want to keep it mounted all the time...
   / My Carryall Project #48
I guess I use my bucket for carrying lots of things and, yes, sometimes forget to take them out before I use my bucket. But I am really wondering when would I use this carryall versus putting things in the scoop because 1) it ties up the 3 pt which I have lots of attachments for and 2) you have to handload everything whereas the scoop just digs in.
The one use I do see for it is firewood. it would be really handy to be able to haul more firewood out of the trees at one time and my trailer can be a little cumbersome in trees. I am just trying to get a handle on what type of projects I would use it for so that I do not buy something else that collects rust out back.
   / My Carryall Project #49
The main use of mine is for firewood. Both sides and the front are removable for other applications. Sometimes I stack cinder blocks in it for rear ballast. Put my generator in it for transporting to work area, etc. In this pic its on my previous tractor.
   / My Carryall Project #50
Thanks for the pictures. Good thread
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
iDrive TDS-2010H...
KBH 25T Tender (A56438)
KBH 25T Tender...
500BBL WHEELED...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
