My Carryall Project
   / My Carryall Project
Nice project. If you wanted to haul firewood or whatever it would be easy enough to prefab sides that go on + off.
Looks good though!
Thanks! I didn't put sides on it since I have a FEL for loads like that...:)
CTF - were you able to get one of the Cat 1 pins to fit? I couldn't find one that did when I went to buy one of these? Love the project.
Dana
Yes, the short cat. 1 pin fit but it was a little close. The medium one is a little long, but that's what I'm using...I bought one of each just to be safe...;)
   / My Carryall Project #43
Nice job.
I built my own weight box for my BX. The shape is pretty close to the Kubota box, but I modified it quite a bit. I used expanded metal grating for the bottom so it won't hold water and added some brackets on the backside of it to hold a shovel, a pitchfork and a rake.
I've got a small tool box in there and as of yet, have never actually used it as a weight box. It's only been used as a carryall.
Here is the latest pic of the carryall. I moved the SMV sign to the side.
   / My Carryall Project #46
Here are some "In Progress" photos:
I have to ask - what do you use this for? I am thinking I could carry things in the scoop and leave my blade, tiller, or whatever hanging on the back. I could see it used for firewood to get it out of the tree lot but what else do you use it for? Just curious.
I use it for hauling around all kinds of stuff I don't want to put in the loader bucket. The only other rear attachment we have is the backhoe, and with it's size I don't want to keep it mounted all the time...
   / My Carryall Project #48
I guess I use my bucket for carrying lots of things and, yes, sometimes forget to take them out before I use my bucket. But I am really wondering when would I use this carryall versus putting things in the scoop because 1) it ties up the 3 pt which I have lots of attachments for and 2) you have to handload everything whereas the scoop just digs in.
The one use I do see for it is firewood. it would be really handy to be able to haul more firewood out of the trees at one time and my trailer can be a little cumbersome in trees. I am just trying to get a handle on what type of projects I would use it for so that I do not buy something else that collects rust out back.
   / My Carryall Project #49
The main use of mine is for firewood. Both sides and the front are removable for other applications. Sometimes I stack cinder blocks in it for rear ballast. Put my generator in it for transporting to work area, etc. In this pic its on my previous tractor.
   / My Carryall Project #50
Thanks for the pictures. Good thread
2018 Chevrolet Malibu 2LT Sedan (A55853)
2018 Chevrolet...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
1461 (A57192)
1461 (A57192)
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
