GC Tractor Owners with Most Hours and Longest Ownership
/ GC Tractor Owners with Most Hours and Longest Ownership #1
cdaigle430
Maine
MF GC2410
Looking for the most hours on a GC series tractor and the longes ownership of one.
Reason I am asking is, for those with the most hours or longest ownership time, what, if any, problems have you encountered?
/ GC Tractor Owners with Most Hours and Longest Ownership #2
My GC2300 is at 550 hrs, either a 04 or 05, not sure, used for snowblowing thru up to 6 ft drifts, wallenstein BX42 chipper in summer, only problem was eating up the front end gears, factory defect, covered by MF , was NOT under warranty.
I am happy!!!
/ GC Tractor Owners with Most Hours and Longest Ownership #3
I am happy!!!
You, my friend, have a good dealer. Don't loose them!!:thumbsup:
/ GC Tractor Owners with Most Hours and Longest Ownership #4
The oldest GC's are from 2005 the model year.
That's what mine is. I have owned it since new.
/ GC Tractor Owners with Most Hours and Longest Ownership #5
My 2310 is an '07, now has about 220 hrs. Problems have mostly been relatively minor:
I re-routed some hydraulic hoses and tie-wrapped them into their new positions to prevent chafing, and in one case slipped some plastic hose over a hydraulic hose to protect it;
I've managed to bust off both ROPS lights, repaired them, broke 'em off again :ashamed:.... eventually replaced them both with Kubota lights, which were less expensive and a bit smaller;
Found all 4 mounting bolts for the 2360 blower loose, re-torqued them and haven't had any further issues;
A few obstinate zerk fittings, either replaced them or pulled them off, cleaned & re-installed them;
Added a temp gauge, which I felt was a necessary addition;
Also added a flat-4 connector to the electric chute controls on the blower.
And only two :thumbsup: really significant problems, a broken ground strap/cable (some of these used a cable that was just too short, IMHO) and two hydraulic hoses that let go at 180 hrs or so.
I also recently added a second ground cable on the other side of the engine, and I swear it cranks much faster now; it really acts as though it's got a new battery when starting, but it's still the original.
Overall, it's been a great investment and I'm still very happy with it.:)
/ GC Tractor Owners with Most Hours and Longest Ownership #6
I've got like 6hrs and have had no problems yet. Do I win something?
/ GC Tractor Owners with Most Hours and Longest Ownership #7
08 with 262 Hrs.--Kill switch in seat frozen up.
KAL you win the slacker award---Get tractoring buddy!!!:):thumbsup:
/ GC Tractor Owners with Most Hours and Longest Ownership #8
We shall see if this snow prediction materializes. Not holding my breath...
Hey! I've only had the thing a couple of weeks!!!
/ GC Tractor Owners with Most Hours and Longest Ownership #9
Mine's a 2007 GC2300 and as of today it's got a mere 1678 hrs.Running just fine.Of course like any piece of equipment it did have some problems,all were fixable of course.Last year in the spring the muffler flange broke off right at where it bolts onto the exhaust manifold.[Fixed just by welding it back together] it's been good since.I had a annoying oil leak comming from the RH break shaft.Had to replace the o-ring that's in there.Oh yeah had to pull the rear diff and remove the side cover to get inside to remove the shaft and then the o-ring.Replaced o-rings on the hydralic control valve.Had to replace a cradle brg inside the hydro unit,plus when the brg broke shards of metal scored the swash plate so I had to replace that plus have the barrel lapped as well.In all honesty the tractor was bought cheaply with 1200 hrs on it due to the hydro not working right.I don't know how it was worked before I got it but since I've had it since June 2009 it's been used but not abused and I'am sure it'll be good to me for many yrs to come.Heck any tractor is going to need something eventually.All I know is I enjoy using it and getting as much seat time as I can. Larry
/ GC Tractor Owners with Most Hours and Longest Ownership #10
"Mine's a 2007 GC2300 and as of today it's got a mere 1678 hrs"...
I think you got me beat!:laughing::laughing: Nice to know my LRB should have a lot of life left in her- don't expect I'll live long enough to need another one at the rate I'm going!
/ GC Tractor Owners with Most Hours and Longest Ownership #11
Well, at least I know who to ask if I have any hydro issues!!;) Congrats on the hrs. Man, that makes me feel good about my purchase.:thumbsup:
/ GC Tractor Owners with Most Hours and Longest Ownership #12
Hey can we add the 1500 series to the mix. They have been out for awhile now too. Think they just added a new one 1525 or something. Figured I would ask before I listed mine.
/ GC Tractor Owners with Most Hours and Longest Ownership #13
07 2310 had 387 hrs on it. Blew up radiator, loose nut got caught between fan and radiator. Bought new radiator. Friend broke off FEL joystick, made new one. Welded MMM frame couple of times. Great machine, but just traded it in yesterday.
/ GC Tractor Owners with Most Hours and Longest Ownership #14
For what did you trade?
I have an '07 with only 140 hours on it and only had minor problem with the FEL float (fixed by dealer, at my home, no charge). I've done some bone headed things like broke a hydraulic hose (my fault), ripped one of those rubber things on the tie rod (?), broke a few sheer pins...the usual stuff.
But every time I use this tractor, I am so pleased with my decision to buy it that I just smile all over.
We may get a foot or so of snow tomorrow, and I'm looking forward to donning the trusty Carhartts, Mad Bomber hat, and LL Bean boots - and having some tractor fun. :D
/ GC Tractor Owners with Most Hours and Longest Ownership #15
I suggest this thread not turn into a list of everything that has been repaired on your tractor. Especially, those without context. For example, someone could give the appearance of lots defects, when actually the repairs were the result of operator error.
Remember, everything you post is here forever, for anyone to read. Consider there is not necessarily a competing brand version, listing hrs, and repairs, for a fair comparison, for someone who is interested in buying a used subcompact, maybe yours, and reading these threads.
We do have some ability to affect our own resale values. :thumbsup:
/ GC Tractor Owners with Most Hours and Longest Ownership #16
Doubtful that the ramblings of a small sample of relatively anonymous posters would have such an effect on an entire market. Every forum I have seen has similar threads, and I haven't seen that reported as contributing to the decline of Mercedes, BMW, Harley, or you name it.
At the same time, that is how trends are often discovered as seemingly random pieces of information are put together in ways that result in better products, better public heath, and a general improvement of Karma in the universe. :)
/ GC Tractor Owners with Most Hours and Longest Ownership #17
Have you ever heard of Google?
I have surprisingly come across lots of TBN posts, while searching on Google. Some I was part of. Try it for yourself, try searching GC 2300 problems, and see what happens. First thing you see is TBN threads offered up. Once a buyer finds TBN, it's all here.
A prospective buyer who knows no one, who owns one, has few other options, but to use the internet for opinions.
I don't buy anything anymore, without looking for reviews on the internet. When more people discover that as an asset, potentially all these posts will be here for them to read.
/ GC Tractor Owners with Most Hours and Longest Ownership #18
07 2310 with 163 hours. 1 blown FEL hose after many, many bucket loads of dirt and gravel. No other problems at all and I've asked an awful lot from my little SCUT.
For ray66v we'll have to agree to disagree about forum posts. I use the forum to identify possible problems and find fixes. I learned not to use the steering wheel to pull myself onto the tractor. I learned the hydraulic hoses aren't the highes quality. I started the thread on 2360 snowthrower chute deflector actuators freezing due to water intrusion into the gearbox and found others that had the same problem. I don't care about resale value as much as I care about finding and fixing any problems.
/ GC Tractor Owners with Most Hours and Longest Ownership #19
Radiator - I dont know, maybe my fault
FEL joystick - my friends fault, he was not aware of the proper dismount techniques
MMM - probably my fault, you're mowing close enough when you hit it.
Hole in Hydraulic hose - my fault, was in the way of the 3PH arm
This is a great machine, my own stupidity caused 99% of the problems.
Traded up to a B3200, wanted to go bigger. As far as resale value, after almost 400 hours I traded for about 3K less than I bought it.
/ GC Tractor Owners with Most Hours and Longest Ownership #20
No, I never said not to use this forum to discuss problems and fixes, that is what it is for.
I suggested it would be counter productive, and unnecessary to use THIS THREAD as a running list of repairs everyone has done without much, or any context.
Would you also pay $15,000 for a stock, and then going on the internet and tell people how bad it is?
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
KUBOTA BX2350 TRACTOR (A60430)
KUBOTA BX2350...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
