Getting Kubota TLB L46. Need some help
   / Getting Kubota TLB L46. Need some help #81
Not sure where your from but in CA yes, if you tow a trailer with a 12k GCWR you are illegal unless you have a Class A. Anything towed that has the weight rating over 10k lbs requires a Class A (can be a non-commercial) no matter what you tow it with. And yes you can go down to your local DMV (at least here in CA) and have your trailer de-rated to 10k lbs (its actually 10001 lbs that makes you illegal without a Class A) to be legal, then they will re-print the registration with the new numbers and you can then change the tag on the trailer. Good for you to buy something rated well above what you intend to haul.
Anything?
   / Getting Kubota TLB L46. Need some help #84
Duffster,
Which one of these best fits your trailer - you do have a trailer for your MF?
Given the amount of dialogue in this thread it would be nice to see your tractor and towing rig as your profile is a bit vague in this regard..
Thanks
   / Getting Kubota TLB L46. Need some help #85
Duffster,
Thanks
Here's mine and a couple more I own. L45 , B26 , BX2230.
   / Getting Kubota TLB L46. Need some help #86
Sure did.
You sure there is no limit on a RV trailer?
Well acctually Duff, there is now similar restrictions on RV's here in CA. I THINK it says you can tow up to a 10k GVWR tag trailer with a Class C and up to 15k GVWR fifth wheel with the proper endorcement, and a Motorhome over 45' requires a non-commercial Class B. These laws are fairly new and very unenforced at this time(till someone kills someone). So why do you care about that anyhow?
   / Getting Kubota TLB L46. Need some help #88
Man Rotor REALLY nice set-up's you got there. Just curious, why a L45 and a B26? You able to keep them both busy out there? Good for you if that's the case.
Thank You HUTCH, The B26 is gone now. And still have the BX2230 & L45. I am able to keep both busy. I do alot of brush hog work with the L45 and the BX2230 is for home and some side jobs.
I was trying to show I actually do own and haul stuff and work with equipment not just play one on the Internet. :thumbsup:
As you can plainly see. I also have a 30ft travel trailer I haul around camping with the family you can see it in the back ground of the one picture.
I am pretty well up on the rules and Reg's here in P.A. ( AT LEAST I THOUGHT I WAS )
P.A strictly enforces the rules and Reg's here.( D.O.T ) is out in full force, a few years back we had a guy hauling a wood chipper illegally and not properly secured and it came loose going down the highway and Killed a Father & His to small children. ( Very sad ) But since then things changed and in there eyes Ignorance of the law is no excuse no matter how you try and bend or twist it. With them this is how it reads and that's it.
One more thing I forgot, I am a aircraft technician buy trade and have been for 25years. When it comes to reading rules and Reg's that our government writes you better know what little words like ( If , Or, To, And, Is ) mean. These are words that will get you in trouble if not defined right. Remember a president that said one time ( It all depends on what your definition of ( IS ) IS. If my memory severs me right he was impeached.
   / Getting Kubota TLB L46. Need some help #89
Duffster,
Thanks
I have trailer that would work for both of those.
Look around I have posted a picture of one of my tow rig combinations. Not that it matters.
One of the combos I use the most is a F350 with a 14k GVWR gooseneck trailer that I could drive in any state in this country without a class A or CDL.
Sorry if I don't list every truck, tractor, trailer, implement and 3/4 inch wrench like some here do.
   / Getting Kubota TLB L46. Need some help #90
Good question.:)
   / Getting Kubota TLB L46. Need some help #91
:rolleyes:
Does this mean you are starting to get it?
This is hilarious.
This is truly scary.
Do you use your backhoe for business or purely recreational use?
   / Getting Kubota TLB L46. Need some help #92
arrrrrrrrrrrrrgggggggggggghhhhhhhhhhhhhhh
don't we do this every few months.
go google the rules. fmcsa, read them, get back with us.
over 26,000 CGVW (rated, not hauling) requires a CDL (unless it's an RV, firetruck, some farm exceptions)
a combined rig with a trailer of 10k lbs or less (total over 26k) requires a class B
a combined rig with a trailer over 10k lbs requires an class A
a pickup truck with a 14k trailer is about 24k CGVW
using the rules from fmcsa, what type of CDL do they require??????
TRICK QUESTION, they do not require a CDL at all.
they MIGHT require a USDOT number if using it for commercial purposes, again, SEE FMCSA
   / Getting Kubota TLB L46. Need some help #93
You must have missed the memo too.
Apparently PA throws federal regulation to the wind and plays by their own rules. :rolleyes:
   / Getting Kubota TLB L46. Need some help #94
The way I THOUGHT I understood this and may be wrong after suffering through this thread.
If your combined weight of truck and trailer is less than 26,000 lbs then you don't need a cdl for private use.
My 110tlb with cab is about 8000 lbs, carrying an additional implement (say the boxblade is another 1250 lbs since it is the heaviest implement) and add the trailer weight with spare and chains 2650 lbs. 8000+1250+2650=11,900 lbs. Trailer is rated for 12,000 lbs and that is very close! I seldom if ever carry the boxblade and the hoe at the same time but for sake of arguement lets assume the 12,000 lb. trailer is loaded.
Living in the mountains I wanted to have a truck that was safe to pull this trailer, so in 2005 when I purchased the tlb I also bought a new truck. The truck is an F550 4x4 service truck which is rated for 19,000 lbs and has a 33,000 lb tow package. The ACTUAL weight of the truck is 11,800 lbs aprroximately (depending on what is being hauled in the bed). If the truck is 12,000 lbs and the trailer is 12,000 lbs my total weight is 24,000 lbs and less than 26,000 lbs in all cases.
So do the reguations require me to have a cdl for a rig that is under 26,000 lbs in actual weight? I purchased the larger truck for safety reasons but may still get in trouble if I understand this. It appears that the "rated load" seems to supercede the actual load. The trucks gcwr is 33,000 lbs ( a Ford spec), the trucks gwr is 19,000 lbs and the trailer is a 12,000 wr pull type.
   / Getting Kubota TLB L46. Need some help #95
Yes. Your GCWR (or CGVWR) is 31,000 and your trailer is over 10k GVWR requiring a CDL class A.
   / Getting Kubota TLB L46. Need some help #97
Thanks for the responses, guess I will make plans to get the cdl license when I have the chance.:(
   / Getting Kubota TLB L46. Need some help #98
I have read all of this thread and a few others on other sites and they all seem to turn out like this. :laughing:
I own a company and run a few trucks to haul my stuff and have spent a little time on the phone talking to goverment employs. Most of the time it goes like this thread. The problem is a goverment employee wrote this and you can read it both way. Being if you need a CDL if the trailer is over or under 10,000 lb. So yes a state employee can and will write you a ticket, doesn't mean their right. You just have to have the facts. I think the link to the DOT site Duffster posted nails it under the questions and guidance as they call it, more goverment speak. So here it is for those that didn't click his link. The first three questions seem to clear this up for me. I am putting a copy in all my trucks.
I think this first question goes to a state can do what they want if you live there but for the next part see questions three. If you don't like your states rules, move.
Question 1: May a State expand a vehicle group to include vehicles that do not meet the Federal definition of the group?
Guidance: Yes, if: a. A person who tests in a vehicle that does not meet the Federal standard for the Group(s) for which the issued CDL would otherwise be valid, is restricted to vehicles not meeting the Federal definition of such Group(s); and b. The restriction is fully explained on the license.
I think question two is about as clear as you can make it about the 10,000 trailer limit.
Question 2: Is a driver of a combination vehicle with a Gross Combination Weight Rating (GCWR) of less than 26,001 pounds required to obtain a CDL even if the trailer Gross Vehicle Weight Rating (GVWR) is more than 10,000 pounds?
Guidance: No, because the Gross Combination Weight Rating (GCWR) is less than 26,001 pounds. The driver would need a CDL if the vehicle is transporting HM requiring the vehicle to be placarded or if it is designed to transport 16 or more persons.
The way I read this is if you are good in your state your good in others. You may have to go to court to prove it for some goverment employees but that is the reason I am putting this in my trucks.
Question 3: Can a State which expands the vehicle group descriptions in ァ383.91 enforce those expansions on out-of-State Commercial Motor Vehicle (CMV) drivers by requiring them to have a CDL?
Guidance: No. They must recognize out-of-State licenses that have been validly issued in accordance with the Federal standards and operative licensing compacts
So Jenkinph is correct in you need a CDL because a F550 has a GCWR of 30,000 lb but he could get a F350 with a GCWR of 23,500 to 24,500 and tow a trailer of 14,800 to 16,500 and not need a CDL.
Roger
   / Getting Kubota TLB L46. Need some help #99
Tailrotor,
Do you have a class B since a class B is needed for any trailer 10k or under?
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
RING 2 STARTS HERE @ 9:15 AM (A60432)
RING 2 STARTS HERE...
UNUSED 250 GALLON FUEL TANK (A60432)
UNUSED 250 GALLON...
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
