Getting Kubota TLB L46. Need some help
   / Getting Kubota TLB L46. Need some help #51
You really are A PIECE OF WORK! Read what it says over 10k trailer let me say it sloooow for you. The 26k applies to a single vehicle or truck and trailer combined. Then READ or,or,or a trailer in excess of 10k. Which in this case the orignal poster would need a trailer rated at over 10k to haul around a M59. I tried but I just can't fix stupid!!
Ok, then let me quote the exact line for you.
Any combination of vehicles with a gross combination weight rating (GCWR) of 26,001 pounds or more if the vehicle(s) being towed has a gross vehicle weight rating (GVWR) of more than 10,000 pounds. Vehicles in this class include:
The relevant word is if not or.
All of these weights are GVWR, not actual load in the truck/on the trailer.
The class A cdl is only needed when both the power unit exceeds 26001 AND the trailer exceeds 10,000.
Class B is needed when the power unit exceeds 26001 AND the trailer is less than 10,000.
Neither case would be true with a 3/4 ton pickup and a trailer in the 12-14k range.
I've gone over the scales in that configuration and the State Police said have a nice day. I'm sure if I was in an improper configuration we would have had a conversation about it as many other vehicles were getting citations.
I believe all the states have adopted the Federal Commercial Motor Vehicle Safety Act of 1986, and are part of a nationally uniform system of classifying, testing, and licensing commercial vehicle drivers.
   / Getting Kubota TLB L46. Need some help #52
I don't need fact,
Ya they just get in the way. :laughing:
anyone that reads this forum, And many others were you post already know what I am talking about.
Frankly anyone that can READ can click the links I post and read the rules and regulations for themselves and see the you are blowing smoke up everyones arse.
I just hope the moderator will also see and track you post and see the pattern you have:
What? A pattern of posting facts and quoting the regulations?
What if I have a truck with a GVWR of 19k towing a trailer with a GVWR of 10k. What do I need then?
How come you can't answer this question?
   / Getting Kubota TLB L46. Need some help #53
This is for you ,Read and understand: http://piv.pivpiv.dk/
   / Getting Kubota TLB L46. Need some help #54
Repost since it got "skipped":
This topic has clearly gone astray, but it interests me.
I have been reading Kubota literature until I am blue in the face about L39/45. It appears one of their MAIN selling points is that these machines are "easily transported by a 3/4 ton pickup truck and 10,000-pound GVWR trailer". They go further to say "requires ONLY a C class license in most states".
10k is a magic number somewhere along the way.
ac
   / Getting Kubota TLB L46. Need some help #55
ac
avc8130
Yes it is!! But some just don't get it.
   / Getting Kubota TLB L46. Need some help #56
ac
It didn't get missed.... I thought it was obvious from the regs that were being quoted.
If you have a > 26,000 tow vehicle, then a < 10,000 trailer means you only need a B CDL to move the combination, rather than an A CDL.
   / Getting Kubota TLB L46. Need some help #58
ac
This just doesn't fit the debate at hand.
   / Getting Kubota TLB L46. Need some help #59
You'll have to excuse me for getting somewhat back on topic here, but could you tell me why the 5240 wasn't big enough for you? I'm asking as that is the tractor I'm eying.....
Thanks.
I am still very happy with the M59, granted it's pretty pricey and you can find used "Big Iron" for about the same money. A primary concern when I was looking to upgrade from 5240, I needed to keep the weight in check with my tow vehicle and needed the versatility of being able to install a 3 point hitch. I'm not saying its the perfect machine but for once in a long time I am no longer shopping for a replacement.
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
16ft T/A Utility Trailer (A59231)
16ft T/A Utility...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
