Virgin Ground
   / Virgin Ground #32
Good thread, I learned something today. That doesn't always happen! :)
   / Virgin Ground #33
Hi deereman,
You may find this Soil Tillage Intensity rating scale helpful.
- Spindifferent
   / Virgin Ground
On "virgin ground", how soon before planting should you work up the ground?
   / Virgin Ground #35
Typically, you would want to turn the field in the fall or early winter, let it lay up in the rough until early spring. Then disc about every 2-3 weeks after a rain. Disc/rototill immediately before sowing/planting the seed. Ken Sweet
   / Virgin Ground #36
anyone use a disc plow? what makes it better/worse/different than a moldboard?
I have a Ferguson 2 disk plow and it digs like you wouldn't believe. It should cut most roots where a mold board might get caught. I believe it will dig much deeper than an disc harrow. You may not need to go too deep for food plots for deer.
   / Virgin Ground #37
Ken, do you know where I could get the "end cap" for a Ferguson like you are referring to. Mine didn't have it, but it didn't cost $900 either. Works OK with out but makes a nice place for wasps to nest.
   / Virgin Ground #38
I sure don't. I would cut me a round piece out of 1/8 flat stock and weld it to the end of the tube. Ken Sweet
   / Virgin Ground #39
i guess you are right, it's not "virgin" ground it just hasnt been farmed for 40 years. It's a 7 acre field that i want to put pumpkins in. I have been looking at tillers for my JD 2440 and i'm liking the king kutter 5' or 6' tillers. I thought about discing it but discs are mainly for leveling ground not tearing it up.
Deereman are you adding 7 more acres to the 15 you already plant with pumpkins? You are going to have one large patch.
Last summer my son and I planted corn and pumpkins on 3-1/2 acres of freshly worked ground. We started May 5th and planted the first corn on May 15th, ten days later, and then bi-weekly until late June. We planted our pumpkins and gourds around the middle of June.
This ground, like yours, has not been worked for many many years.
  1. Day 1 we plowed the ground with our two bottom plow.
  2. Day 3 we disced several times.
  3. Day 5 we disced again.
  4. Day 6 we tilled.
  5. Day 9 we tilled again.
  6. Day 10 we planted first 1/2 acre of corn.
For the pumpkins we added 550lbs of MAP (11-52-0) as per soil test a week or so before planting and disced it all in. We did not use any herbicides.
I can post pictures of most of the steps if you like.
   / Virgin Ground
pictures would be great
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
Ryobi Drill (A57454)
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Manual Aluminum 16ft Man Lift (A57454)
Manual Aluminum...
