2320 hydro drive shaft just snapped off !!!
   / 2320 hydro drive shaft just snapped off !!! #41
JDdude said:
U would be better off with a unit that has a straight shaft without ujoint from the engine to the trans..As far as I can tell the 2520 is not built like this.
That's correct, the engine in the 2520 is rigidly attached to the transmission through the tunnel housing. There is a splined coupling directly connecting the drive shaft from the engine to the input shaft of the hydrostatic drive, no u-joints.
   / 2320 hydro drive shaft just snapped off !!! #42
That must be why the 2320 doesn't have a hump in the operator's deck, where as the 2520 does have one.
   / 2320 hydro drive shaft just snapped off !!! #43
Nothing is mentioned about greasing this in the manual. Nor is there anything about replacing it, etc. I just went and checked and there are no grease fittings on this U-Joint nor the U-joint for the shaft that goes to the front axle.
For what it's worth: I am on my tractor almost everyday and it has not sounded or acted funny until the 20 seconds it start making that noise before I shut it down. I am guessing that noise was the U-Joint coming apart/vibrating and causing all that wear.
Mechanic friend coming in about 30 minutes to look at it....and then I will be heading to JD dealer to show them the pics and see what they say.
Check out this.
http://www.mytractorforum.com/showthread.php?t=103618&highlight=part+2
   / 2320 hydro drive shaft just snapped off !!! #45
Interesting....
If there was truly no mention of greasing these u-joints in the owners manual I would be raising h*ll at the Deere dealer, to the Deere regional service manager, etc on up the line until the repair was covered in full. The failure was a classic u-joint failure which also took out the shaft. Obviously it had never been greased since new, and if there was no mention in the owners manual to do so I personally would expect Deere to cover the bill.
   / 2320 hydro drive shaft just snapped off !!! #46
Interesting....
That will definitely give you some good ammunition in the discussions.
   / 2320 hydro drive shaft just snapped off !!! #47
I'm betting there was no mention because there are multiple suppliers some are sealed some have zerks. It wouldn't surprise me if there were u-joints on the same tractor with and without zerks.
Did the OP mention definitively what type of joint was on his tractor?
   / 2320 hydro drive shaft just snapped off !!! #48
Nothin for nothin but the picture below (right out of my 2320 owners manual) shows the grease fittings to be greased on the 2320.
I know for a fact there are many more under the tractor but I can not find a sole that can tell me, show me or point me to a manual that shows the locations.
FYI: The U-joint going from the Hydro Drive the Front Axel (the one NOT busted) does NOT have any Zerks on it.
From what I see from the blown up u-joint, I don't see a Zerk.....but it is in pieces and some can't be found.
Boy...this is just fun....learn something new everyday. :confused2:
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
J and L Cargo Express Shadowmaster Enclosed Trailer (A51039)
J and L Cargo...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
