Antifreeze odor 97 F150 4x4
   / Antifreeze odor 97 F150 4x4 #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I have a 97 F150 4x4 w/ the 4.6 and everytime I drive a while and exit the truck, I smell antifreeze. I have checked high and low, every hose, heating core and so on and cannot find a leak. The motor was replaced 2 years ago and has about 25k miles on it. The only thing I can figure is it is coming from the degas container by the driver's fender. Anyone have any thoughts??
   / Antifreeze odor 97 F150 4x4 #2
Any drop in the fluid level?
Chris
   / Antifreeze odor 97 F150 4x4 #3
How good is your nose? I once had a very similiar experience. I told my father I could smell coolant when driving an auto I had years ago. With him being the auto mechanic, he took it out for a drive - no problem, no smell, no leaks. I drove it another couple weeks - still smelled it. By this time heater core had dripped a few drops in the passenger floorboard - ah ha - heater core was the culprit.
Chris
No, none. The only thing I can figure is it is the container "degassing". The cap was replaced about 2 years ago, just before the motor. No water or coolant in the oil either.
   / Antifreeze odor 97 F150 4x4 #5
I agree,check the heater core.
   / Antifreeze odor 97 F150 4x4 #6
x 3 heater core check. it doesn't have to be a big leak, just a few drops. and once you get the A/C or heater or like going. it just fills the vehicle.
   / Antifreeze odor 97 F150 4x4 #7
X4 heater or lines
   / Antifreeze odor 97 F150 4x4 #8
If it's the heater core, I sure hope it's an easy job. I got lucky on my 1984 F150 and didn't have to remove anything but the glove box to get at it.
Unfortunately, I hear the later model F series requires removal of the dashboard....
Good luck.
   / Antifreeze odor 97 F150 4x4 #9
Luckily if the 97 is like the 96, and I believe it is, really easy job.
In fact you might just want to remove the cover and have a look.
I once changed a heater core in a Taurus about that vintage, don't want to talk about it, apparently the heater core is the first part on the assembly line then the entire car is built around it...I still twitch involuntarily when I see a Taurus:laughing:
   / Antifreeze odor 97 F150 4x4 #10
Had the same problem with an old Thunderbird, just a slight antifreeze smell, and finally noticed a slight amount of greasy film on the inside of the windshield. Of course it was the heater core..so completely disassembled the car, and when nothing was left bolted together, replaced the core.:laughing:
James K0UA
3 Point Hitch Hay Spear (A57454)
3 Point Hitch Hay...
New/Unused Double Stall Portable Toilet (A57453)
New/Unused Double...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
Snap On MT 926 Multimeter (A57454)
Snap On MT 926...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2017 Jeep Wrangler Unlimited Sport (MPV), VIN # 1C4BJWDG5HL577343 (A57453)
2017 Jeep Wrangler...
