Plow
   / Plow #11
   / Plow #12
Heres a link to a plow that looks to me like that one if not you have earlier version.Made by Brinly for JD ? :confused2:
http://www.tractorbynet.com/forums/john-deere-owning-operating/105007-jd-2305-single-mold-board.html
Not trying to sling the mud just trying to help.If its not accept my appoligy.
Many blessings wished to all TBN family folks out there. :)
Boone
I never said that Brinly made plows for JD. Brinly quit making plows a few years ago. JD bought that part of Brinly's buisness.
Also, if you look at the mast, it is close to a Brinly but the Cat 1 top link on the tractor will not fit on a Cat 0 Brinly. I know because I tried to do it once with my 2305. The coulter wheel arm has an offset bent in it. Brinly never did that. Most of them are bent back a little but that is from hitting something hard enough in the field to bend it. The beam in the pic appears to be one thick piece of steel. Brinly's are 2 pieces. This one has no standard. Brinly's standard is bolted inside the beem.
I hope this helps. :)
   / Plow #13
Read my p-link #11.
I never said you or anyone else said they made plows for JD.Just ran accross that old link and it looked "simular" to me.I even appoligized forehand if it was'nt.
Boone
iDrive TDS-2010H...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
CATERPILLAR 299D3 SKID STEER (A60429)
CATERPILLAR 299D3...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
Case skid steer wheels and tires (A56438)
Case skid steer...
