Hp required for 3 point chipper?
   / Hp required for 3 point chipper? #1
Dave Wave
I am interested in putting a Jinam chipper on a tractor with 28hp at the PTO.
The spec on the chipper is 15-50 HP.
Does anybody have any insight as to what sort of performance can be expected with 28 HP?
Thanks,
-Dave
   / Hp required for 3 point chipper? #2
You should be fine . I ran a 21hp with a 3pt chipper and only had to back off if I got into bigger limbs . 4" is fine over that in hardwood might make her smoke a bit!
   / Hp required for 3 point chipper? #4
I have a 6" Jinma on a 24 pto hp tractor. Just keep the rpm up and the blades sharp. Fresh cut wood isn't much of a problem, old dry wood can really make her chug.
   / Hp required for 3 point chipper? #5
Thanks,
-Dave
I have the 6" Jimna and have run it for years with my JD870......28 HP tractor. Has plenty of power to operate it. Never any issues. Just dont get ahead of yourself when feeding larger logs into it or it could jamb up in the chute.
As long as chips are flying out...all is well. I chip bull pine, branches from fir and tamarack.
If it does clog up, not to hard to clear out. Remove the chute, blow out the crud.
So how big dia. branch will this thing chip with 24 HP?
Is it just a matter of backing off the feed when chipping big stuff?
Thanks,
-Dave
   / Hp required for 3 point chipper? #7
Thanks,
-Dave
My old Deere had 24 PTO HP and ran a Woods 5000 chipper (5" capacity). There was no problem whatsoever. Just load the branch or trunk in the chute (gravity feed), step back and let the chipper do the work.
   / Hp required for 3 point chipper? #8
I have a 5" BearCat with a blower on my 28 hp pto. The same as Roy's Woods unit I think but with the added blower. He and the others are right, you will be fine. After a little op time you will learn how to feed it. Keep the knives sharp - dirt and pebbles are bad. And chip green wood if you can - dryed wood is tougher. If I have a 5" piece I usually cut it into 18" or 24" lenghts before I drop it in the chute or I overload the blower.
   / Hp required for 3 point chipper? #9
Yep...blower is an option with the Woods. As I bought it used and I didn't want to spend another $750 for the blower kit, I can rake those chips.
Bearcat actually makes the 5000. Woods just markets them.
   / Hp required for 3 point chipper? #10
i have fed 6" max (at base) entire trees less the branches thru my Jimna (have 24hp pto with a 28HP tractor, and it worked fine. But usually i cut the 6" and larger for firewood. I generally am chipping 4" and smaller.
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
24220 (A56859)
24220 (A56859)
