New Holland vs Kuhn Disc mower
   / New Holland vs Kuhn Disc mower #21
you dont have to repair drive shafts on the NH because of the module design, with the shear hubs, etc. if you hit something it is 10 minutes of changing a $30 to $40 dollar shear hub and off you go. but for 3 years that is warranty anyway......
What drives each module 1 long hexagon drive shaft or have they came up with another way to drive the pods? Ken Sweet
   / New Holland vs Kuhn Disc mower #23
I believe the NH design is the way to go.
I do see what Ken is saying about the Fort. It brakes away if you hit something. That's ok if just the blade hub is damaged. But if something happens deeper into the bar....Hmmmm.
And with my luck, it would!
If something happens between the pinion gears, like a idler gear or bearing goes out, we can repair that in about 2 hours. Ken Sweet
   / New Holland vs Kuhn Disc mower #24
no they have individual shafts that runs from each module to the other not one long shaft the runs the lent of the cutter bar like the old bushhog hay cutters
   / New Holland vs Kuhn Disc mower #26
Neighbour has one of the NH shear hubs, he's been disappointed in how easily they shear, and how far they go. He's lost a few already.
   / New Holland vs Kuhn Disc mower #27
Thats why I like the Massey Ferguson (New Idea). It also runs on segmented shafts. undo two bolts to split it and put it back together. They have been running these for years and is pretty much what everybody used in my area.
Just had to throw that in.
   / New Holland vs Kuhn Disc mower #28
he must be having some other issues going on. all of our customers can go at least a season or two without shearing any at all.
   / New Holland vs Kuhn Disc mower #29
Why would you ever shear one unless you hit a fence post or well casing? Ken Sweet
   / New Holland vs Kuhn Disc mower #30
i have never sheared one on mine but then i try and only cut fields that i have walked and no there is nothing in there
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
2020 Golf club car (A53424)
2020 Golf club car...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53473)
NEW 2025 Load...
2011 GALYEAN 130BBL VACUUM TRAILER (A53843)
2011 GALYEAN...
2013 FRAC TANK (A53843)
2013 FRAC TANK...
