I wanted a new plow but I couldn't afford it so
   / I wanted a new plow but I couldn't afford it so #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
I am buying this blade.
RBT3584 Price quote given, money in the bank
Land Pride RBT35 Series Rear Blades
it's a 7 footer. Kinda wondering if I should go 8 foot. That's all that's holding up me pulling the trigger.
   / I wanted a new plow but I couldn't afford it so #2
Lets see if I got this?:confused:
you wanted a plow, your getting a rear blade!:confused3:
Two diffrent function,
I'm trying to follow your logic here!:confused2:
I'm all for you getting more stuff. :thumbsup:
LMAO :laughing: :laughing:
I wanted this plow but in a two bottom
Kuhn Master 102-T
http://www.psndealer.com/powersportsdlr/images/NewVehicles/NV109067_1_400.jpg
It's $9500 and change delivered to my door.:shocked:
I already have the old Ford two bottom so...
I'm buying a blade instead. :thumbsup:
Good logic huh?:confused2:
   / I wanted a new plow but I couldn't afford it so #4
A 7' rear blade can plow ... very, very wide rows :laughing:
   / I wanted a new plow but I couldn't afford it so #6
I use a 7ft. behind a L4240,at full angle is covers the back tires.
   / I wanted a new plow but I couldn't afford it so #9
I would love to have that blade, very, very nice.
A few years ago around here, you could buy good sized moldboard plows for the price of scrap, we picked up a good three bottom Massey Ferguson for about $150 bucks as that is all we needed. Hardly anyone uses plows here anymore.
   / I wanted a new plow but I couldn't afford it so #10
That sure is a fine rear blade. Being hydraulically adjustable it may not be an issue but I like to turn my blade 180 degrees for some applications. If the blade is too wide you can only do that with it removed from the tractor. Nybirdman makes a good point. You want it to cover your foot print when angled. Bet you knew that.
MarkV
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 GALYEAN...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2006 GMC C5500 BUCKET TRUCK (A59905)
2006 GMC C5500...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
