Tires L-3130-HST right tire wear on outside. front axle problem.
   / L-3130-HST right tire wear on outside. front axle problem. #22
It's not 2". Attached is a shot of the toe-in adjustment spec from the L3130 manual.
attachment.php
At 2 inches your tires will not last very long... the outside edge of one will grind off...
Are you sure it isn't 2 cm ?? Even that is a LOT for use on hard surfaces... KennyV
I will call the dealer monday to find out what they say.
Thanks
attachment.php
AH HAH!!!! That's it!!! I read it wrong...I forgot Kubota is foreign!!!
Thanks everybody for all your help....I think we nailed it down, now I can buy some new tires!!! OH Boy!!!DUHH!!!:ashamed:
   / L-3130-HST right tire wear on outside. front axle problem. #26
   / L-3130-HST right tire wear on outside. front axle problem. #27
Well ... at least you didn't go for the 8 side of the (2 to 8 mm) and set it at 8 inches toe in... that may have required you to use the rear wheel lock to move forward...
Glad you are soon to be in a much better handling and steering tractor... KennyV
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
2010 VOLVO VN-VNL T/A ROAD TRACTOR (A57192)
2010 VOLVO VN-VNL...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2001 John Deere M665 60in Zero Turn Commercial Mower (A55851)
2001 John Deere...
UNUSED FUTURE VR59 59" HYD VIBRATORY ROLLER (A57193)
UNUSED FUTURE VR59...
2003 GMC C7500 Utility Flatbed Service Truck (A55852)
2003 GMC C7500...
