Tires L-3130-HST right tire wear on outside. front axle problem.
   / L-3130-HST right tire wear on outside. front axle problem. #22
It's not 2". Attached is a shot of the toe-in adjustment spec from the L3130 manual.
attachment.php
At 2 inches your tires will not last very long... the outside edge of one will grind off...
Are you sure it isn't 2 cm ?? Even that is a LOT for use on hard surfaces... KennyV
I will call the dealer monday to find out what they say.
Thanks
attachment.php
AH HAH!!!! That's it!!! I read it wrong...I forgot Kubota is foreign!!!
Thanks everybody for all your help....I think we nailed it down, now I can buy some new tires!!! OH Boy!!!DUHH!!!:ashamed:
   / L-3130-HST right tire wear on outside. front axle problem. #26
   / L-3130-HST right tire wear on outside. front axle problem. #27
Well ... at least you didn't go for the 8 side of the (2 to 8 mm) and set it at 8 inches toe in... that may have required you to use the rear wheel lock to move forward...
Glad you are soon to be in a much better handling and steering tractor... KennyV
2023 John Deere 9RX 640 Track Tractor (A53485)
2023 John Deere...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2001 Dodge Ram 1500 Pickup Truck (A55852)
2001 Dodge Ram...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2017 BOBCAT S770 SKID STEER (A52707)
2017 BOBCAT S770...
2019 BOBCAT T595 SKID STEER (A52707)
2019 BOBCAT T595...
