Pre drilled holes? In bucket
   / Pre drilled holes? In bucket #1
whitmerlegacyfarm
Central PA
2010 Kioti DK50SE HST w/ 401 Loader
Hey guys my new dk50 hst shows up in mornin. Does the buckets have the holes pre drilled for a tooth bar? Was curious. Ifnot I was goin to c if they are able to drill those holes so I wouldnt have to once my toothbar shows up. Dont have the tools to dril threw that thick of steel. My neighbor does though lol. Thanks guys I will post pics as soon as I get a chance. Rain,is in forecast for the next 5 days so lil down I mite not get to use much. Thanks
   / Pre drilled holes? In bucket #2
Never have seen a bucket pre drilled for a tooth bar. I would wait till I had the tooth bar to make sure the holes were in the right place. :thumbsup:
   / Pre drilled holes? In bucket #3
Toothbars don't have standardized mounts so you really need to fit the toothbar yourself and then drill the holes. The good news is that bucket sides are usually only 12 or 14 gauge or so and drilling the holes is easy even with homeiwner grade tools. A bolt on cutting bar is different and drilling for that could be a real pain.
   / Pre drilled holes? In bucket #4
well, my 2011 - DK45 has several sets of holes predrilled in the bucket. 6 on the lower lip and 2 on each side......guess there for a toothbar....but i dont like using toothbars, so for me it didnt matter. see pics
   / Pre drilled holes? In bucket #5
my bucket sides are 3/16" steel...14 gauge is awfully thin
hmmmm... So as far as clearin brush n wantin to do a lil level of ground wat options are thete other then a tooth bar? Are there issues using them or something?
   / Pre drilled holes? In bucket #7
I'm not sure what the holes on the side of your bucket are for.
But they are way to high to be for a toothbar.
   / Pre drilled holes? In bucket #8
its just the kind of terrain i have, no real brush.lots of gravel and dirt. the tooth bars tend to leave grove marks. the plain bucket leaves it smoother. i guess it depends on the kind of terrain you have.
Ive rented equipment in the past with tooth bars, great for digging holes, and moving out dense underbrush. I just don't have this.
anyways, I'm not sure if the holes in my bucket are intended to fit a certain brand of toothbar or if there universal. I'm not sure what kinds of attachments Kioti sells under its own branding.
I have ordered a set of pallet forks for mine, and i hope that these will help me when clearing logs, branches, etc. time will tell. There due to arrive this Monday.:) :licking:
   / Pre drilled holes? In bucket #9
im not sure what the side holes are for. im refering to the 6 lower holes. the side holes may be for some kind of grapple???? id love to find out what there for. the dealer isnt even sure what there for.
   / Pre drilled holes? In bucket #10
The 6 lower holes are for a bolt on cutting edge/wear bar.
   / Pre drilled holes? In bucket #11
is that what there for...thank you. ive been wondering what there for.
I even emailed Kioti a few days ago. havnt heard back from them yet.
But now i know :) :)
   / Pre drilled holes? In bucket #12
My toothbar slides over the bucket cutting edge and is held in place by 2 bolts (one on each side of the bucket).
I can install or remove it in minutes.
   / Pre drilled holes? In bucket #13
Well, I admit I estimated but 12 gauge is pretty close to 1/8 inch. I can measure mine next time I am near the tractor but I'd be surprised at 3/16ths. However, I've been wrong before!:laughing:
I did drill the toothbar holes on my CK20 bucket and those were certainly not hard to do with a battery powered drill.
   / Pre drilled holes? In bucket #14
i measured mine with a digital thickness device when i was designing a trailer moving device.
   / Pre drilled holes? In bucket #15
Wait until you have the tooth bar. Most of them have a fixed bolt and one that has a slot type attachment. If you locate the holes properly, you can loosen the bolt in the slot one and flip up the tooth bar for backstabbing with the tooth bar out of the way.
Thanks so much all yet once again for all the info. I will just wait. Im off to work fora few hrs n when I gethome the new dk50 should b sittin in the pole barn. Rainin or not im gettina lil seat time! Pack here I come. Lol
   / Pre drilled holes? In bucket #17
The holes in the side of the buckets are used to attach the bucket to the pallet for shipping. Before you ask why are they in both side then? Because when the end plate are cut and drilled they are the same and it doesn't matter what side they get welded to.;)
Dealer had a tooth bar in stock so they r just gona pre drill it for wat a nice guy. Been a good buyin process with Hoover Tractors.
   / Pre drilled holes? In bucket #19
...... and my tooth bar just slips over the cutting edge and is held on with four "set screws", no holes to drill.
   / Pre drilled holes? In bucket #20
The holes in cutting edge are for extra bolt on cutting edge, as stated earlier, but also for individual teeth to be bolted on. Holes in side of the bucket are for side wear bars to bolt on. At least this is on the Bobcat loader buckets.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
207273 (A52708)
207273 (A52708)
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
