Tub Shower On Concrete Slab
   / Tub Shower On Concrete Slab #11
Enough sand under the bottom of the p-trap to support the drain pipe against downward pressure if you should happen to push on it while putting the drain in.
Other than that, leave the box empty. You don't want to have to repair it, but if you have to you don't want to be chipping concrete out and possibly damaging the drain pipe.
   / Tub Shower On Concrete Slab #12
What would eb recomended if a fiberglass tub was to go over a plywood deck floor?I belive ,ine has fiberglass insulation from 1980. now has seemed solid all these years.. But ill be replacing soon.. thanks
   / Tub Shower On Concrete Slab #13
Yes can place a layer of 4 mil plastic on the plywood deck, place the tub and do the concrete thing as mentioned, or do the concrete and set the tub on it.
   / Tub Shower On Concrete Slab #14
ive seen contractors set fiberglass tubs on concrete and plywood .....they add a layer of plaster first then set tub. the plaster dries and sets tub tight.
   / Tub Shower On Concrete Slab #15
Do the instructions say to set the tub in concrete? If so, fill with sand and skim with concrete. I'd want it supported.
I'm picking the tub up tomorrow, so we'll see what it says in the destructions.
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2006 PETERBILT 379 (A58214)
2006 PETERBILT 379...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
New 40ft High Cube 6 Door Container (A59000)
New 40ft High Cube...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
