Tub Shower On Concrete Slab
   / Tub Shower On Concrete Slab #11
Enough sand under the bottom of the p-trap to support the drain pipe against downward pressure if you should happen to push on it while putting the drain in.
Other than that, leave the box empty. You don't want to have to repair it, but if you have to you don't want to be chipping concrete out and possibly damaging the drain pipe.
   / Tub Shower On Concrete Slab #12
What would eb recomended if a fiberglass tub was to go over a plywood deck floor?I belive ,ine has fiberglass insulation from 1980. now has seemed solid all these years.. But ill be replacing soon.. thanks
   / Tub Shower On Concrete Slab #13
Yes can place a layer of 4 mil plastic on the plywood deck, place the tub and do the concrete thing as mentioned, or do the concrete and set the tub on it.
   / Tub Shower On Concrete Slab #14
ive seen contractors set fiberglass tubs on concrete and plywood .....they add a layer of plaster first then set tub. the plaster dries and sets tub tight.
   / Tub Shower On Concrete Slab #15
Do the instructions say to set the tub in concrete? If so, fill with sand and skim with concrete. I'd want it supported.
I'm picking the tub up tomorrow, so we'll see what it says in the destructions.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2014 International Derrick Digger Truck (A55973)
2014 International...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
NEW Fork Extensions (A59000)
NEW Fork...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
