Tub Shower On Concrete Slab
   / Tub Shower On Concrete Slab #11
Enough sand under the bottom of the p-trap to support the drain pipe against downward pressure if you should happen to push on it while putting the drain in.
Other than that, leave the box empty. You don't want to have to repair it, but if you have to you don't want to be chipping concrete out and possibly damaging the drain pipe.
   / Tub Shower On Concrete Slab #12
What would eb recomended if a fiberglass tub was to go over a plywood deck floor?I belive ,ine has fiberglass insulation from 1980. now has seemed solid all these years.. But ill be replacing soon.. thanks
   / Tub Shower On Concrete Slab #13
Yes can place a layer of 4 mil plastic on the plywood deck, place the tub and do the concrete thing as mentioned, or do the concrete and set the tub on it.
   / Tub Shower On Concrete Slab #14
ive seen contractors set fiberglass tubs on concrete and plywood .....they add a layer of plaster first then set tub. the plaster dries and sets tub tight.
   / Tub Shower On Concrete Slab #15
Do the instructions say to set the tub in concrete? If so, fill with sand and skim with concrete. I'd want it supported.
I'm picking the tub up tomorrow, so we'll see what it says in the destructions.
2022 Horizon Trailer (A55973)
2022 Horizon...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2011 DODGE RAM (A56858)
2011 DODGE RAM...
CAST IRON POT (A58374)
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
