those that have a L 40 series kubota
   / those that have a L 40 series kubota #1
VA MTN MAN
Virginia
kubota m5700
I just purchased a new 5740 and am wondering if this is normal. On a steep downhill the hydro trans seems to give and go while holding the tractor back. I have a 4610 with hydro and in the same situation if you hold the pedal at a certain point it will hold you back at that exact speed. the new one seems to give and catch. Do yours do that.
Thanks
   / those that have a L 40 series kubota #2
Haven't noticed it with my 5240 , have a guy with a 5740 doing a job I'll check with him too.
   / those that have a L 40 series kubota #3
I have the smaller L3240 but have never experienced anything like you are describing.Mine seems to hold a steady speed on down hills.
   / those that have a L 40 series kubota #4
I haven't noticed that on my L3940, but it's pretty flat everywhere I operate mine.
   / those that have a L 40 series kubota #5
That is not normal for an HST. What range were you in?
   / those that have a L 40 series kubota #7
Does it let completely go and then grab or does it pick up speed smoothly?
   / those that have a L 40 series kubota #8
Mine did it until I realized that because I didn't have loaded tires and if I was in 2wd the rear tires would slide. I could hear the tires sliding though, in a caab that could be a little harder.
   / those that have a L 40 series kubota #9
Doesn't happen on my L4740 and I run on some pretty steep slopes.
   / those that have a L 40 series kubota #10
Thanks
Is the HST fluid low, perhaps? If you are on a steep slope, low fluid may be letting air into the transmission circuits, causing it to freewheel intermittently.
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
Kubota 29" Excavator Bucket (A50774)
Kubota 29"...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
12" Tooth Bucket (A50774)
12" Tooth Bucket...
