those that have a L 40 series kubota
   / those that have a L 40 series kubota #1
VA MTN MAN
Virginia
kubota m5700
I just purchased a new 5740 and am wondering if this is normal. On a steep downhill the hydro trans seems to give and go while holding the tractor back. I have a 4610 with hydro and in the same situation if you hold the pedal at a certain point it will hold you back at that exact speed. the new one seems to give and catch. Do yours do that.
Thanks
   / those that have a L 40 series kubota #2
Haven't noticed it with my 5240 , have a guy with a 5740 doing a job I'll check with him too.
   / those that have a L 40 series kubota #3
I have the smaller L3240 but have never experienced anything like you are describing.Mine seems to hold a steady speed on down hills.
   / those that have a L 40 series kubota #4
I haven't noticed that on my L3940, but it's pretty flat everywhere I operate mine.
   / those that have a L 40 series kubota #5
That is not normal for an HST. What range were you in?
   / those that have a L 40 series kubota #7
Does it let completely go and then grab or does it pick up speed smoothly?
   / those that have a L 40 series kubota #8
Mine did it until I realized that because I didn't have loaded tires and if I was in 2wd the rear tires would slide. I could hear the tires sliding though, in a caab that could be a little harder.
   / those that have a L 40 series kubota #9
Doesn't happen on my L4740 and I run on some pretty steep slopes.
   / those that have a L 40 series kubota #10
Thanks
Is the HST fluid low, perhaps? If you are on a steep slope, low fluid may be letting air into the transmission circuits, causing it to freewheel intermittently.
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
