Lawn roller - Modifying to fill with water
   / Lawn roller - Modifying to fill with water #1
JayC
MI's Thumb
I recently acquired an old lawn roller that was home made. It was made out of an old, round gas tank. On top it has a place to put weight. There is no way to add water. I'd rather be able to fill it with water instead of trying to find a bunch of weight to put on top of it. My question is, what do I need to put a hole in it to fill it with water and then plug the hole? Sorry for the stupid question. :eek: Thanks!
   / Lawn roller - Modifying to fill with water #2
Torch a small hole and weld a big nut over it. Use the bolt as the filler/drain plug. Probably want a good sized nut you can run a garden hose thru.
That's a good idea! :thumbsup: I hadn't thought of that. Now I just gotta find someone with a torch and welder. :laughing:
   / Lawn roller - Modifying to fill with water #4
Great idea.
How about welding a pipe coupling with a threaded plug. Might be a better seal.
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
404 (A52706)
404 (A52706)
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
CATERPILLAR 308E2 CR EXCAVATOR (A60429)
CATERPILLAR 308E2...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
