Things to inspect on manure spredders
   / Things to inspect on manure spredders #1
Learning to Farm
20 minutes from downtown Washington, DC
Kubota L3750
I have not one but two manure spreaders provided by the farm, I would like to know what to look at to see if they are in "working" order. They have sat out in the weather for at least 2 years. What maintenance should I do before using them (I figure check the tires and air pressure). On a side note, I plan on spreading compost with them from composted horse manure, is there maintenance I should do after I have finished the job? I will be storing them in a covered equipment area.
   / Things to inspect on manure spredders #2
Much will depend on what type/style the spreaders are that you have. Care to post a pic or two, and the make and model #'s ? I'd suggest some "dry" runs with nothing in them, to see if the mecahnical parts are working (after checking for any broken or missing parts).
   / Things to inspect on manure spredders #3
I have a horse drawn (or tractor drawn) spreader from the 1950's (best as anyone can tell).
All parts are available thru "Shoup" online store. They dont have many moving parts, and i usually have to fix something every season.
Not to hard to repair actually.....
   / Things to inspect on manure spredders #4
I would lube all chains and grease all zerk points before moving the spreader. As suggested earlier, I would make some dry runs to be sure all is working ok. Ken Sweet
Been, here you go!
#1 is a AGCO New Idea 3709 is the number.
#2 is up on the hill and I will take more pictures later
Grt, funny thing. For my main job I travel, I have been to the town that Shoups is in (noticed on the website). Secondly, if you fix something every year, farmers should charge more for food (always a belief of mine) a chain assembly is 600+$.
Thanks!
   / Things to inspect on manure spredders #6
The gearbox is the most important part. I would turn the PTO by hand first to make sure everything is free. If something is jammed up, you could break the gearbox. Big troubles. Everything else is open and pretty obvious. Check front to back for grease points (gearbox for lube). Don't forget to look under for broke/rotted hangers.
   / Things to inspect on manure spredders #7
Thanks!
As a life long farmer, I can say from experience, that as a producer, we have absolutely NO control over what we get for our product. We generally pay high input costs and sell low to middle. That is why most farmers have off farm jobs to subsidize our farming. Ken Sweet
   / Things to inspect on manure spredders #8
From the pics, looks like the apron will need to be fixed, as one or two flights appear to be broken away from the square chain. You'll get some learning on how to slip apart the square chain links (having the right anvil tool will help a lot here) and possibly how to repair the rivets that connect the flights (cross bars) to the special links. Having a neighbor or friend nearby as a tutor will help a lot here.
Getting a manual with parts breakdown will help a lot.
I happened to catch one of the guys that does some maintaining on the farm this weekend. There are many broken/rusted snapped flights (learned a new word). He said that yes, the power part is fine but the chain had jumped and a lot of the flights are broken. If I buy a new set it is $450. That maybe easier than learning to wield. Haha!
   / Things to inspect on manure spredders #10
Never heard of the term flights..... i have been able to get parts for mine thru "Shoup's". most parts , if not all, on the roller chains can be poped out and replaced without replacing the entire chain assembly.
are flights part of the gears???? or the chains??
2005 VOLVO VNL SLEEPER (A54607)
2005 VOLVO VNL...
2014 Ram 1500 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 Crew...
BUSH HOG 1815R1 BATWING MOWER (A51406)
BUSH HOG 1815R1...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
