A question about washing my tractor??
/ A question about washing my tractor?? #1
Gobblin Tom
Gold Member
Western, PA
2011 JD 2520
I have been doing a lot of work in the woods with my new JD 2520, I have been trying to get my paths straightened out but have run into 5-6 springs along the way so things have been interesting to say the least!! Anyway I was just curious if it would hurt the tractor to use the power washer? I don't know if there is any areas that I should be careful as in electronics, etc. I really want to get the under carriage cleaned before putting the mower deck back on. Oh yeah this is one situation that I wished I had the back hoe....:(
/ A question about washing my tractor?? #2
No problem I have a 4000PSI washer not a mark on my tractors.
/ A question about washing my tractor?? #3
This is where you want to have one of the low pressure ones. I have seen real high pressure washers peel paint. I would not hold it too close.
/ A question about washing my tractor?? #4
Ha! There you go. We both answered at the same time with conflicting answers. Go figure. :)
Yeah I know you can't hold it to close..... was more worried about seals and electronics.....
/ A question about washing my tractor?? #6
you just may want to be careful around any stickers/labels.
/ A question about washing my tractor?? #7
I would just use a hose with a fairly good nozzle. A pressure washer is over kill and risky for just washing the crud off of a tractor.
/ A question about washing my tractor?? #8
A ham fisted operator can break anything....
Use a 4000 PSI washer at 1" with a 0-degree tip and you'll do damage. A 2000 psi unit at 3' with a 45 degree tip probably has less cleaning power than a garden hose.
Pressure washing is fine, if you are smart about how and where you direct the streams.
Start with a wider spray and work at a distance, if you are not getting the cleaning you need, get closer and/or narrow the pattern.
/ A question about washing my tractor?? #9
Pressure washer works great, to remove that really thick mud, just don't blow the stickers off of it, or soak the alternator or anything like that, I go easy on the dash panel also, but other wise just wash away.. Mine is 2700 lbs.. just use common sense.
James K0UA
I have a lot of clay stuck on it and I just have a spring for my hose so I don't have a lot of pressure (Has a pump though). I don't think the hose will come close to removing the clay....????
/ A question about washing my tractor?? #11
ive used powerwashers on tractors many times, and the only problem i have ever had was the mud/clay blowback onto ME.
man, was i a mess afterwords. but the tractor never was hurt. all good powerwashers come with multiple tips and just use a good wide spray pattern to prevent damage.
/ A question about washing my tractor?? #12
I thought it was just me... I keep a special 'pressure washing' t-shirt so the wife doesn't get too upset with me messing up clothes.
/ A question about washing my tractor?? #13
I'm with you. No problem washing, but see no reason to go to higher pressure than the 40-50 psi from the hose.
Clay mud is/can be hard to get off, but not letting it dry on is helpful.
/ A question about washing my tractor?? #14
A good trick for loosening up all the crud on the bottom is to just hook up a standard $5 lawn sprinkler to your hose and set it underneath it and let it swish back and forth for a couple of hours. Will keep everything from drying and keeps you from having to get a face full of the thick mud.
/ A question about washing my tractor?? #15
I like that trick. :D
/ A question about washing my tractor?? #16
I have clay dirt down here that stick to tractor tires etc as tight as white is on rice. Pressure washing is the only way I can go.
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2014 Sea Ray 250SLX Bowrider Boat with T/A Boat Trailer (A59231)
2014 Sea Ray...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
