Mower blade shape?
   / Mower blade shape? #11
Whatever the goal is, a plan to have to mow 20 acres of grass sounds like the wrong direction to me.
Native prairie of some kind, grazing animals, trees possibly, all these are low energy input ideas, with environmental responsibility. Mowing is a luxury cosmetic solution, and 20 acres is extreme. My opinion, no offense intended to you, maybe you have way more money and time than I can imagine.
   / Mower blade shape? #12
I've got 2 mowers that are used to cut grass around the home place. One is a JD260, the other is a JD265 (One gear, one hydrostat) BOTH have identical 48" decks. The 260 has a good set of OEM Deere blades (medium lift) The 265 has gator blades, bend creating lift appears to be very much the same as the Deere blades.
That said, the Gator Blades show NO....NONE....ZERO....additional mulching capabilities. The ONLY difference I can see is they're a higher quality of steel (harder????) and hold an edge MUCH better in the same conditions.
Yes, I plan on staying with Gator Blades, but it is NOT because of their "mulching abilities" (which I find to be almost non-existent)
   / Mower blade shape? #13
Thats odd, because I notice a prety good difference in mulching. ESPECIALL when the leaves fall. I have ran them on two mowers now, a JD261 3PH mower, and My SCAG 61" ZTR.
Are you sure you have TRUE gator blades and not the knockoffs. The knockoffs have the fins twisted the opposite direction and throws grass away from the blades after it is cut. The real gators have the fins turned so that the grass is thrown back toward the center of the blade so it can be chopped up again.
   / Mower blade shape? #14
The flail mowers used for road side verges and vegetation control have either the scoop knives or the hammer knives and that is why the cut is so rough on thin vegetation.
If you buy a finish mower flail mower with the high number knive count from Ken Sweet you will never use your rotaries again when you see how well the cut is and how healthy your sod will become.
A rotary mower, rotary cutter or rear mounted rotary finish mower tears the grass and brush rather than slicing it like the verticut method with a finish mower flail mower.
The Sainfoin seed would work well for you as it is much less expensive than
Zoysia seed for your property as you can have them planted with a sure stand grass seed drill and have a high germination rate rather than losing a lot of seed when using a broadcast spreader.
   / Mower blade shape? #15
I have "true" GATOR BLADE brand blades.....
   / Mower blade shape? #16
The "healthiest" turf you'll ever run across is generally found on professional sports fields and golf courses. They mow with either bed knife mowers OR rotary mowers WITH SHARP BLADES. They tear grass LESS than other alternatives. (I'm a member @ Valhalla Golf Club, former site of 2 US Opens, Ryder Cup, and PGA SR Open, and also a member on their advisory board. BTDT with the golf course mowers) With a premier level golf course, money, time, and effort aren't even really considerations. It's all about what gives the best looking, most consistant playing surface. I've yet to see a fairway mower that's NOT a rotary cutter or an old fashioned bed knife mower.
I'm in the "industry" as far as mowing goes.....We've demo-ed flail mowers on several occasions. (inc. Alamo commercial grade at that!) Where they fall short is in VERY high use (hours) circumstances. They become quite "maintenance intensive" after a time (relative to rotary mowers) .
Flails are great in certain circumstances, but like anything, they aren't the answer for every situation.
To each his own, I guess. Bought this acreage Jan. 2010 - after a lot of preliminary work, fields were covered with a mixture of tall grasses and some wildflowers. Pretty to look at in the wind, but loaded with little critters that attracted snakes, possum, raccoons and roaming coyotes. With 9 grandchildren and 5 dogs, was always a bit apprehensive to turn them loose on the property.
As mentioned, didn't buy property to farm and/or raise animals. Also have enough trees - 20 acres with walking trails and partially cleared park-like areas. I could have bought this property and sat on my front porch drinking cool ones, but at 64, might not survive the boredom for long.
Not at all concerned about the environmental impact of my diesel exhaust - I'm surrounded by hundreds of beef cattle and farmers growing hay to feed them. Add to that the thousand of commuters who sit in traffic (for hours) on their way to cooled mega buildings, only to punch keyboards tied to energy sucking mainframes powered by a coal burning electrical plant.
Am I rich with too much time on my hand? No to the first - never made a salary to put me in the rich category. Was raised by parents who grew up in the depression, however. and they taught me at an early age how to manage ones income. When times are hard - cut back. When times are good - save most of the excess. And - unlike current dogma - you can't borrow yourself out of debt. I've been saving for well over 50 years - it's paid off.
Yes and probably yes - but I've reached a time in my life where I'm going to do what pleasures me - I've earned it.
   / Mower blade shape? #18
The "healthiest" turf you'll ever run across is generally found on professional sports fields and golf courses. They mow with either bed knife mowers OR rotary mowers WITH SHARP BLADES. They tear grass LESS than other alternatives. (I'm a member @ Valhalla Golf Club, former site of US Open, Ryder Cup, and SR Open, and also a member on their advisory board. BTDT with the golf course mowers)
I'm in the "industry" as far as mowing goes.....We've used flail mowers on occasion. (Alamo commercial grade at that) Where they fall short is in high use (hours) circumstances. They become quite "maintenance intensive" after a time (relative to rotary mowers) .
ON this WE disagree,
Half the problem is improper operating speed for the flail rotor; if the flail rotor
is not running high speed at the recommended 540 R.P.M. speed for the tractors Power Take Off or if the prime mover is traveling too fast the quality of cut will be very poor or just plain crap.
Flail mowers become maintenance intensive when they are abused, hangers are not inspected and replaced when needed, knives are not sharpened or replaced when broken during operation, and not greased when needed.
The flailmowers bearings are the most sensitive part of a flailmower, wherein if wire or baling twine gets wrapped around the bearing housing it holds the heat and fries the grease in the bearings.
I love how my turf looks everytime I mow with my flail finish mower and I have very little grass to pick up.
I can buy replacement Y blades and dethatching blades for my Lawn Genie from flailmaster and others and wheels and bearings from Palmetto specialty tire.
I mow brush and good sod and have been doing the same thing every year and I am able obtain a beautiful finish everytime I clear brush or mow down to sod.
As far as high use we have 32 years on our towed Mathews Co. Lawn Genie with main bearings and simple engine parts and basic repairs.
Other than the obvious reason of Alamo Industrial eliminating The Mott Mower Company as Competiton, you cannot purchase a reliable and safe towed motorised flail mower from an American manufacturer now and I will have to import one when and if the time comes.
I still shake my head everytime I think about the time the Alamo Salesman at the Empire Farm Days told me towed motorised flail mowers were unsafe to own and operate(we know he did not own one for sure).
We both know the real reason is the cost to manufacture a very high quality mower.
   / Mower blade shape? #19
No problem with you disagreeing, but I'm not buying a few of your "reasons why".
I have a 2 man maintenance crew that does nothing but service mowers and tractors in the fleet. My equipment is maintained far more intensively than any manufacturer specs. Operational speeds are relatively slow (ground speed) because of circumstances (usually people/vehicles present) PTO speeds are kept @ (or VERY near) 540 or 1000 (as equipment needs) The quality of cut IS NOT the limiting factor (in my case) it's overly demanding maintenance/replacement requirements during high hours usage.
And, with regards to the golf course use.....There is NO baling wire, stumps, car parts, fence posts, ect to contend with. Just perfectly groomed, clean turf. So "abuse" isn't the logic behind using rotary turf mowers. It's all about results. There are several well known manufacturers of golf course turf equipment (inc John Deere) None (that I'm aware of) offer flail type fairway mowers. This is in a "money is no object" market, so I'd expect there is no reason why cost to produce one would be the limiting factor (in this case)
Local turf farm (who sells to several golf course contractors) mows over 200 acres of irrigated zoysia, bluegrass, and bentgrass turf several times per WEEK, ALL with a John Deere ROTARY fairway mower.
Again, NOT "slamming" flails, just stating the obvious.....There are other alternatives that net results as good, and do so at less cost and less maintenance required.
My mowing business logs (last season) over 6000 hours of combined use on multiple mowing rigs. We are constantly on the lookout for new and improved methods of mowing. (to improve speed, cost, AND quality of cut) I've tried a number of flails (different brands) with mixed results. AS I said, they aren't the "one and only answer" to a multitude of problems. Glad you're pleased with yours.
   / Mower blade shape? #20
But.....Our President says we can borrow our way to prosperity ;)
At any rate, I feel ya on the "do what pleasures me" thing! I have 11 acres of "lawn" in between 2 hay fields. Some would say it's lost hay production, other say too much grass to cut. You know what? It isn't taking hay outta their barn, and they aren't the one who has to cut the grass.... It gives me joy to look out my windows and see lush green grass. I pay the bill, I spend the time. I'm the only one who needs to approve of it in my eyes.
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
2019 DODGE RAM 5500 HD SERVICE TRUCK (A54756)
2019 DODGE RAM...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
