Hesson 1014 Haybine and HP
   / Hesson 1014 Haybine and HP #1
bruwen811
White 1470
I can buy a Hesston 1014 Haybine, does any one know how HP you need to run this machine
Thanks
Thanks for the info, how did the swing draw bar work
   / Hesson 1014 Haybine and HP #4
Once you use a center pivot machine you will never want to go back to a side pull unit. period.
   / Hesson 1014 Haybine and HP #5
Ain't that the truth!.
However i installed a restrictor in the swing cyl lines to slow down the swing speed switching from side to side.
   / Hesson 1014 Haybine and HP #6
I have to disagree. I have both, a Kuhn center pivot and a JD side pivot and each have their strong points, depending on field accessability and shape.
The 1014 that I bought is a 10ft version and has the semi side pivote, how is it different than a center pivote
   / Hesson 1014 Haybine and HP #8
To each his own. I never encountered a field that wasn't easier to mow with a center pivot than not.
SCAN TO RECEIVE TEXT UPDATES (A51246)
SCAN TO RECEIVE...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
2024 JOHN DEERE FC 10 R LOT IDENTIFIER 79 (A53084)
2024 JOHN DEERE FC...
