Hesson 1014 Haybine and HP
   / Hesson 1014 Haybine and HP #1
bruwen811
White 1470
I can buy a Hesston 1014 Haybine, does any one know how HP you need to run this machine
Thanks
Thanks for the info, how did the swing draw bar work
   / Hesson 1014 Haybine and HP #4
Once you use a center pivot machine you will never want to go back to a side pull unit. period.
   / Hesson 1014 Haybine and HP #5
Ain't that the truth!.
However i installed a restrictor in the swing cyl lines to slow down the swing speed switching from side to side.
   / Hesson 1014 Haybine and HP #6
I have to disagree. I have both, a Kuhn center pivot and a JD side pivot and each have their strong points, depending on field accessability and shape.
The 1014 that I bought is a 10ft version and has the semi side pivote, how is it different than a center pivote
   / Hesson 1014 Haybine and HP #8
To each his own. I never encountered a field that wasn't easier to mow with a center pivot than not.
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
FAKE (A52472)
FAKE (A52472)
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
