Hesson 1014 Haybine and HP
   / Hesson 1014 Haybine and HP #1
bruwen811
White 1470
I can buy a Hesston 1014 Haybine, does any one know how HP you need to run this machine
Thanks
Thanks for the info, how did the swing draw bar work
   / Hesson 1014 Haybine and HP #4
Once you use a center pivot machine you will never want to go back to a side pull unit. period.
   / Hesson 1014 Haybine and HP #5
Ain't that the truth!.
However i installed a restrictor in the swing cyl lines to slow down the swing speed switching from side to side.
   / Hesson 1014 Haybine and HP #6
I have to disagree. I have both, a Kuhn center pivot and a JD side pivot and each have their strong points, depending on field accessability and shape.
The 1014 that I bought is a 10ft version and has the semi side pivote, how is it different than a center pivote
   / Hesson 1014 Haybine and HP #8
To each his own. I never encountered a field that wasn't easier to mow with a center pivot than not.
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A51039)
2022 JCB 3TS-8T...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2018 BIG TEX 35+5 T/A GOOSENECK (A50854)
2018 BIG TEX 35+5...
Kubota L35 4WD Tractor Loader Backhoe (A49461)
Kubota L35 4WD...
